SOURCE: Samsung Prostar 816
The battery is dead and will not maintain system programing after a power outage. If the battery is not replaced this problem will occur everytime the power goes out.
If you have a programming manual you can change the settings on your own. If not, you will need to contact the installer or a local interconnect company that services Samsung. It seems as though the memory switch inside the ksu is turned off. If that's the case, it needs to be turned on and if not, you either have problem with the ksu or the power outage was a brownout. Sometimes a very short loss of power can cause corruptions in memory, however I seriously doubt it in this case. Your system is acting as though it's memory has been set to default.
Good Luck,
BB
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
The code for hold recall is #52
enter in your hold recall time in sec. and in a 3 digit format. i.e. 30 seconds = 030 a minute and a half is 090 and so on.
it sounds like the memory battery on the main board is no longer working which means that it'll happen again.
SOURCE: some 816 phones won't ring on incoming calls
with the handset down, enter #20 the screen should say MMC DISABLED
press # when finished.
SOURCE: My Prostar 816 will not
Testimonial: "Excellent! This fixed my problem! Thank you so, so much!!!!!"
