The Simer brand of submersible dewatering pumps rely on being fully submersed in water for proper cooling and for the seals to remain water tight and effective.
According to the manufacturer, there is no oil used in the pump, other than a very small amount that was used in assembling the pump at the factory, so you shouldn't oil the pump, but rather follow the recommendations as to making sure the pump is installed properly.
Here's the owners manual for your particular pump (Model #2300) so you can check the troubleshooting FAQ's and so you can also contact the manufacturer, should you need replacement parts or need to make a warranty claim, etc.
http://www.simerpumps.com/pdf/1000001370.pdf
Hope you find this Very Helpful and best regards!
