Hi Friend, this is Z. Thank you for your post!
Based on the symptoms you are describing, it appears your Frigidaire range is possibly experiencing a potential wiring failure or a communication problem with the EOC (Electronic Oven Control). Try unplugging your range or flipping the household circuit breaker off first. It is good to wait approximately ten minutes and then turn on your range. If the issue continues, then I recommend contacting a professional to make a precise diagnosis.
SOURCE: cook top elements will not
check the electrical connections to the range and the breaker in the fuse box you only have 120 volts to the unit
SOURCE: oven went out with a pop
Did someone bump the self-cleaning lock lever? If you have one, make sure it is all the way over to the right. Try resetting the unit by tripping the breaker. Leave it off for 30 secs min and turn it back on. See if that works. If not, let us know and we'll help you further.
SOURCE: Frigidaire Gallery Series ES340 ceramic-top range:
The manual is missing a step. After pressing Clean or Quick clean you need to press the ^ button once.
