Mitsubishi WS-65807 65" Rear Projection Television Logo
A
Anonymous Posted on May 21, 2014
WHY WHITE DOTON SCREEN - Mitsubishi WS-65807 65" Rear Projection Television
White Screen I have a white screen and can't get rid of it. I tried taking the batterie out and it still had a white screen and I shut it off and on a lot but still a white screen. What do I do?
check the screen display unit would have been damaged if so
you will be compepelled to replace it do not do it yourself take it to a
reliable repairer
3helpful
My N72 is not showing any display... just a simple white colour screen
Did your phone drop on the flow? Is it just showing white and still works ?or Display white screen and not working?
For a phone to display a white, does questions need to be answered..
If it fell on the flow it's usually a screen fault and it needs to be replaced.
If it didn't fall down, but displays white screen and nothing function,it a software faulty needs a memory restoring..
If just showing white screen and you still can make calls with it, then it's screen fault needs to replace..
1helpful
I HAVE HONDA HS520AS SNOW BLOWER I NEED TIMING MARK IF ANY ONE KNOW PLEASE LET ME KNOW
if you look at the cam shaftand gear,you will see a v on one of the teeth , on the crankshaft agaainst the lobe you will see the gear into which the cam gear meshes ,you will see a doton one of the teeth .the dot and the v(arrow)go together and slide the cam gear into place. when you get to the tappets inlet .006 exhaust .008 .go to it if you need more help just come back to me
10helpful
White Screen
ma k800i has a white screen and i thik its a software problem
Sony screen is white.
is there screen fully white or white screen with some horizontal lines ? pls send ur feed back
2answers
Nokia K750i
If the new screen is white and old screen displays 20% of the display then you can check by flashing the software , in most the cases white screen is the software problem.....
1helpful
White screen on nano ipod
I have had this problem recently myself and would like you to know that it is possible to fix. The white screen error or otherwise known as "white screen of death" is caused by the lcd color screen on the ipod itself. That is why its functions still work but the screen does not. Once you replace the color screen it will be as good as new.
2helpful
2answers
White screen
how do you flash the firmware using pc. can u tell the procedure
White screen on lcd and regular screen
i repaired one not to long ago te flex cable going to the screen from inside the camcoder was cracked
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
