All of the choices for picture size are too large. People's heads are cut off even on the natural setting.
SOURCE: Picture won't change sizes
If you are using a cable box, the settings you want are in the setting menu under "format" or "display" . Typically the choices are Normal or stretch, Select stretch.
The "small picture is how the old NTSC format displays in "normal mode" on a High definition set.
While you are in the settings menu, you might want to verify that the box is set to output at least 720P if not 1080i.
www.mcveyelectronics.com
