DWD F1221
SOURCE: my front loader fills with water, pumps and drains
Remove the back panel of the machine and operate it to check that the drive belts are being engaged to drive the drum. Observe the operation from a safe distance when you have the back off as there are live terminals within reach and you could be severely shocked if you come into contact with any one of them. Unplug the machine again before checking anything withing the workings.
Hello - Washer not filling with water can be caused by many reasons. Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Are the house valves turn on fully? Contact a professional to move forward accurately?
