RCA 25425RE1 Phone Logo
A
Anonymous Posted on May 20, 2014
Why are the buttons not working - RCA 25425RE1 Phone
Nokia C200 power button not working
If the power button on your Nokia C200 is not working, there are a few steps you can try to troubleshoot the issue:
  1. Check for physical damage: If the power button is damaged or broken, it may not function properly. Inspect the button for any visible damage or debris that may be preventing it from working.
  2. Clean the button: If the power button is stuck or not responding, it may be due to dirt or debris lodged in the button. Use a small brush or toothbrush to gently clean around the button and see if this resolves the issue.
  3. Check the button connections: If the power button is not working properly, it may be due to a loose connection or malfunctioning component. Check the connections between the power button and the rest of the device to make sure they are secure.
  4. Reset the device: If the power button is still not working after trying the above steps, you may want to try resetting the device to its factory settings. To do this, go to "Settings," then "Backup and reset" and select "Factory data reset."
1helpful
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
4helpful
2answers
Keypad not working v9 moto
The volume buttons on the side of the phone are sticking. My up volume button seemed fine, but someone told me to keep pushing it and the button will release. Sure enough, the volume controls started to work. I played with both the up and down buttons some more and the button below started working. A few more minutes monkeying around with the volume buttons and now all the buttons work.
The left mouse button does not work on my IBM
Windows has the ability to swap mouse buttons, mainly for those who mouse left-handed. It looks to the right button for left button action. It seems that the actual left button is not functioning. A work-around is to use the right button as the left as you are now doing, AND, use the solid windows button (the one to the immediate left of the right control key) as the right button. Not as easy, but it works.
2answers
PIONEER DEHP3500 ONLY VOLUME BUTTON WORKS PLAYS CD BUT BUTTONS DONT WORK ON CD EITHER RADIO DOES NOT WORK AT ALL
hi im using pioneer DEH-5750MP pnly sound is working and no other button is working ,cd is working fine but cant acces the radio as no other button is working
Button does not work
hi
Some of those buttons work in combination with the two dials (i.e., setting ISO and white balance, etc.). Hold a buttin down and user the knobs simoultaneously.
If this is not the issue, please describe specifically which buttons are not workin...
thank u rate me!!
Print Screen Button not working
Yes, there is a button, up by the function buttons, that says "print screen". I've tried pressing just that button; pressing that button and the alt button together; and pressing the "Mode F" button and the print screen button together, but nothing seems to work
2answers
Samsung- SGH-D820 key problem
Contact problem more common with any phone. Simply problem, somtimes you have to take a part the phone clean it, dry it to fix that.
You can buy a special cleanig solution for wather dammage from ebay if you realy want to fix this alone.
But if you hawe waranty, use ti!!!
Top RCA Lands Phones Experts
k24674
SmartAviator
SmartAviator
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
