Xerox WorkCentre M15i Laser Printer Logo
A
Anonymous Posted on May 20, 2014
HOW TO GET PAGE COUNTS FROM DI251 - Xerox WorkCentre M15i Laser Printer
Di251 driver
The best driver s you mite find for the Di251 is 95 or xp Di251 series is legacy Minolta now konicminolta try their web site but doubt you will find it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
I have a code E000013-0001 code showing on Canon 6055i copier
Its on the rear bottom right, I believe there is two screws, remove the panel and take out the bottle and empty it. After replacing the waste toner case or removing the waste toner from the case, clear the toner counter in service mode as follows:
To get into service mode, hit additional functions[*] 2&8 follow by additional functions[*] again. [Select [COPIER> Counter> MISC> WST-TNR], press "C" (Clear key) to clear the counter, and turn the power OFF/ON.
You can also change the detection level as follows:
The waste toner detection timing is determined by the total page counts specified in service mode below:
1. Page counts until the warning message is indicated
2. Page counts between the warning message and E013 indication
Field Remedy
Follow the steps below if you want to change these page counts:
In service mode [COPIER> Adjust> MISC> WT-FL-LM], select any number from "0" through "4".
0: 80,000 / 1: 140,000 / 2: 210,000 (default) / 3: 320,000 / 4: 460,000
In service mode [COPIER> Adjust> MISC> WT-ER-LV], select any number from "0" though "3".
0: 1 / 1: 20,000 / 2: 40,000 (default) / 3: 60,000
Minolta Di251 All-In-One Printer windows 7 64bit print driver
SORRY Di251 is a Legacy Minolta machine. At best can only use windows 95 or Xp. Minolta is Now KonicaMinolta
How do i replace imaging unit minolta dialta di251
open the right side pull out the old one bye two handles install the new one
Minolta Dis521 paper keeps jamming over and over
Do you mean a Di251? and where is it jamming?
4helpful
C0500 error in a minolta Di251
Does the lid over the toner bottle close properly?
2answers
How do I get a meter reading of number of copies?
Here you go.
  1. Press the [Reports] button on the Control Panel
  2. Press the [Up] or [Down] arrow until 'Systems Data' is displayed on the Display Screen.
  3. Press the [Enter] button.
    The System Data list will be printed with the following information:
    • Total Page Counts: Total number of pages printed
    • CRU Prints: Number of pages printed using the current Toner (Dry Ink) Cartridge
    • Replaced Toner Counts: Number of new Toner Cartridges installed in the machine
    • Replaced Drum Counts: Number of new Drum Cartridges installed in the machine
    • Current Drum Page Counts: Number of pages printed using the current Drum Cartridge
    • Platen Scan Page Counts: Number of pages scanned using the Document Glass
    • ADF Scan Page Counts: Number of pages scanned using the Automatic Document Feeder (ADF)
5helpful
4answers
I wish to read the total copy count on Xerox WorkCentre M15i
You have to print out the meter report.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
