SOURCE: Laptop Cannot Find Home Wireless Network
Try logging into the router with your desktop hard-wired and find the 25-digit passcode and use that to log on to the wireless network with the laptop. If not, then check if connection is good by hard-wiring the router to the laptop. Let me know what happens or if you have solved the problem.
SOURCE: hp Pavilion Media Center TV m7470n Desktop PC does
is ur dvd/cd drive reading other cd/ dvd .if no then the lense of the drive is bad and it needs to be replaced or the cd is bad and has many scratches.
SOURCE: HP Pavilion Media Center a1510 PC desktop, one
One beep means a problem with your processor (CPU). You can try to reset it (there is(are) clip(s) on the side that hold it down to the socket). Unplug everything from your computer before opening. You may need to remove the heat sink on top of the CPU; get some thermal paste to put on the CPU before you replace it. Lift up the clip, make sure the CPU is correctly oriented (one corner is marked) and press it back down. Spread new thermal paste and replace the CPU cooler. Try rebooting the computer. If that doesn't work, you should try a new CPU - match to the socket on the motherboard. Unfortunately, if you use Windows, you will probably need to contact them to ensure that the OS key is valid.
I hope this helps.
(if your computer is really old or was cheap, replacing it with a new machine may be easier. Pull the old hard drive and either install it as a slave drive in the new machine or use a hard drive enclosure (IDE or SATA to USB or eSATA if that is on the new machine), a hard drive dock (SATA) or a IDE/SATA/USB dongle (that lets you connect a bare drive out in the open to the USB port) to get your data from the old computer.)
SOURCE: HP Media Center m7250n - How to hear audio steamefrom panel input
You need to unmute the line-in and adjust its level as necessary. Usually you can just double click on the speaker icon in the system tray and the Line In is by default muted and it is on the far right column (depending on your setup). If it is not displayed, click on Options and Properties and put a check mark by Line-in so that it will display.
SOURCE: I have a HP m7570n.
This depends on the TV's available inputs. The Pavilion m7570n has only a VGA output in the standard configuration.
Thus if the TV has a VGA port, turn off the computer and the TV. Then connect a standard VGA (RGB or D-sub 15-pin) m/m cable between the computer and the TV. To use the TV speakers, connect a 3.5 mm audio patch cable between the computers Line-out (green speaker port) to the VGA audio in. Turn on the TV and set the input to VGA (with the Source or Input button on the remote or the TV). Then turn on the computer. Windows XP should find the correct resolution to work with the TV. (If you turn on the TV after turning on the computer, you may get an unsupported signal. Press Ctrl-Alt-Del twice to restart the computer.) If it doesn't work, you may need to connect a different monitor and set the computer to a low resolution before connecting the TV and the computer.
If the TV only has composite or component video inputs, you will need a VGA to video converter (http://www.svideo.com/pctocomponent.html for example). A VGA to component cable will not work; those are for projectors that read an RGB input. TVs interpret YPbPr.
If you have added a video graphics card, you may have an HDMI and/or DVI port(s) on the card. In that case, check the specs of the TV. Some TVs will support HDMI or DVI-HDMI inputs from a computer. Others will not (since computer video signals are not the same as the signal from a set-top box). If you use a DVI-HDMI connector, make sure to use the HDMI port labeled for DVI and connect the audio cable as with the VGA connection. If you use an HDMI connection, you may need to set the sound properties to that of the HDMI port. (Find the control panel item for sound (under Hardware) and then select Manage Audio Devices. Set the Playback properties. If it doesn't work, use an audio patch cable.) Some TVs have RCA audio inputs for the HDMI-DVI connector. In that case, you will need a female 3.5 mm to RCA M/M adapter (if you use a 3.5 mm patch cable). There is a similar device if you want to use an RCA audio cable. You may need to enable the video ports on the graphics card before swapping monitors.
Some video cards have a TV out. In that case, connect the appropriate connector (should come with the video card). Then connect to the component, composite or S-video input on the TV.
Again turn off the TV and the computer before making any connections.
You will probably need to provide your own cables for must of these connection options.
I hope this helps.
