Question about Jet Tech Systems Dishwashers
We purchased a used Jet-tech dishwasher and cannot figure out how to install the detergent dispenser. Are there technicians in the Clinton/KS, MO area who could come out to help us. We run a Bible camp.
    Problem Solver:
  • 25 Answers
The detergent system on the Jet-Tech machine are all very similar. Near the solenoid valve under the machine, beside the drain connection, there are two wires, one red and one blue. Those wire will run the detergent pump when the machine calls for water. Two tube are attached to the pump. when looking at the pump from the front or clear plastic can be seen, the tube on the left (arrow going up) is connected to the container with the detergent. the tube on the right (arrow down) is connected to the back of the unit to inject the detergent into the tank. Some precaution should be taken to assure that the connections are tight and not leaking. if the tube shows signs of crystals inside, it should be replaced as the detergent as crystallized within. Search by part number or description
Posted on Jul 15, 2014
SOURCE:
  • 76 Answers
SOURCE: maytag mjd 2005dishwasher
Try what my wife does. She uses the individually contained detergent/rinse bubble packs (tab packs). No messy granular detergent and easy to simply place inside the silverware basket. Your dishes should wash spotless, like ours. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 19, 2007
SOURCE: dishwasher's detergent reservoir clogged
I have the same problem...I think I mixed the soap types (Enzyme based with Bleach based). The manual clearly says not to do this.
What I did was brought out my trusty wet-vac and sucked it out while using HOT water to break up the crusty mess. I am going to fill the dispenser with water and add soap the old way until I see the "low soap" light go on.
I'll keep you posted if this happens.
Posted on Feb 01, 2009
SOURCE: smart dispense detergent dispenser
There are two different types of dishwasher detergent types, bleach based and enzyme based.  The owner's manual states that if the two are ever mixed that the mixture will congeal, clogging the dispenser.
I don't know exactly how to safely remove the detergent that is in there, perhaps a wet/dry vaccuum.  There is likely a service mode for the dishwasher if it has electronic buttons, in the service mode you could activate the pump that dispenses the detergent.  Use caution, the thicker the clog, the harder the pump has to work and it may fail.  Hope this helps.
Posted on Apr 15, 2009
  • 17 Answers
SOURCE: where do i put jet dry
Check page 2, number 2 in the owner's manual...
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=DC4000&siteCd=MCF
A liquid rinse aid dispenser is only found in select models. Yours may not have a dispenser.
Posted on May 18, 2009
SOURCE: GE Profile dishwasher with ''SmartDispense'' technology is clogged
I had this problem myself and the purge solution listed above did not work for me. There was just so much gelled and hardened junk in the dispenser container, it would have forever to clean out. Additionally, I think it could have had the chance of damaging the pump. Here is what I did instead:
* Remove power to the dishwasher (via circuit breaker or pull plug under sink).
* Take all dishes and bottom rack out of the dishwasher.
* Close dishwasher door.
* Remove bottom 2 screwbolts with a rachet.
* Open dishwasher door.
* Put a small box that is big enough to hold the panel while the door is opened.
* Remove screws holding inner door to outside panel. Don't remove the screws heading into side of door itself. Also, there are 2 screws near the latch that you don't want to take out...just loosen them and you'll see they don't behave like the other screws.
* The panel will separate from the door, BUT there are 2 ribbon cables connecting them. Have someone hold onto the door...so it won't pull up hard on the ribbon cables.
* GENTLY pull back and forth (side to side) on the white ribbon cable on the door. It will come off with a connector.
* Use a small flathead screwdriver to gently press the tab in on the blue connector and gently pull the blue ribbon cable straight out.
* Remove panel completely and put aside.
* Gently close dishwasher door. It will want to fly up since it doesn't weigh as much.
* Look for a red/green cable from the detergent container (detergent level sensor) and disconnect it.
* Open dishwasher door and take off detergent cap.
* Have someone hold onto the detergent container from the other side and un-twist the detergent locking ring (the item you normally screw the cap into). You can use your hands or put a cloth over it and gently remove with channellock pliers. The detergent container will now be free, but connected to a rubber tube that leads to the detergent dispenser pump. It will easily disconnect by pulling the container away from the tube/pump. The container is now free!
* Shake the living hell out of the detergent container over a trashcan. Mine had tons of white and blue gel in it. Once you remove most of the gunk, bring it under the faucet in the sink and rinse with warm/hot water. Shake, rinse, empty, shake, rinse, empty. The hole where the detergent comes out should be 100% cleaned out. Use the handle of a small paintbrush (or something) to push the hardened gunk out of the hole. Be sure the container is totally cleaned. Take your time on this.
* Put everything back in reverse order. The only thing I did differently is putting the door panel back on the door: Close door, reattach container & cable, bring over panel and re-attach ribbon cables, hang panel on the top two white plastic blocks that you loosened the 2 screws by the latch with earlier. Then screw on the bottom 2 door screws (do not tighten until all screws are put back in place). Put all screws back...don't overtighten.
* Re-apply power and you should see the 'Add detergent' light come on. That's a good sign!!!
* Put in fresh detergent and you should be good to go.
* Lesson learned: DON'T mix enzyme and bleach based detergent ever again!
This was easier than I thought it was going to be...and didn't waste electricity, water, or time based on the purging method. After all, if it is clogged, you can't purge it. Enjoy!
Posted on Jun 19, 2009
Dishwasher tablet does not dissolve so crockery not clean
Are you using a rapid wash program, ie 30 minutes total?
if you are, put the tablet in the cutlery basket, not the soap dispenser. The wash time is very short on the 30 min program, so putting it in the cutlery basket gives it more time to dissolve.
Other problems might be problem with water level, (should be just above the filter but below the lip of the wash tank), pump not working or the spray arms not turning - (check the angled jet at the very end of the spray arm for blockage by food particles).
Feb 04, 2018 | Dishwashers
The dishwasher detergent dispenser is gumming up and dishes are not as clean as they use to get.
Purchase a dishwasher cleaner tablet(s)
You may need to remove and back flush the spray arms
Ensure there is nothing blocking the water intake in the bottom
Your issues seems to be low water flow. These are the simple and inexpensive solutions try the first.
Sep 21, 2017 | Kenmore Dishwashers
White powder residue left on dishes after washing. I run hot water before running dishwasher, use Cascade powder (fill dispenser less than 1/2 full per installer and do not use prewash detergent...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 10, 2010 | Whirlpool DU805DWG Dishwasher
White film on dishes and interior
White streaking is caused by too much rinse agent. (jet dry) Most all dishwashers now have adjustable rinse agent dispensers, so you can set them to a lower setting when you have soft water, and a higher setting if you have harder water. The adjustment is generally right where you add the jet dry. Other possiblilities would be a leaking jet dry cap, or a defective jet dry dispenser.
Apr 16, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
I have a siemens stainless consealed control dishwasher and recently started leaving a whitish film on all glassware. I have tried to turn down level of jet dry dispenser and turn it up but doesn't seem to...
Try "Dishwasher Magic" - which is really just citric acid. You can also use white vinegar in an empty wash cycle. You may also want to try different detergents, and if you can, turn the jet dry setting up and use a bit less detergent.
Mar 04, 2010 | Dishwashers
Dishwasher Detergent Dispenser not opening
An automatic dishwashermag-glass_10x10.gif detergent dispenser door can become stuck for a few different reasons. Some problems are easy to fix, while some require more work. Repairs are basically the same no matter what brand of automatic dishwasher you have, although specific parts might be required. Fortunately, even if the detergent dispenser needs to be replaced, the problem is not an emergency. The dishwasher will clean dishes fine even with a stuck detergent dispenser.
    Fixing a Stuck Automatic Dishwasher Detergent Dispenser
  1. Step 1 Move the basket that holds silverware as far from the detergent dispenser as possible, or make sure no tall items are blocking the dispenser. Also, keep other items such as plates and pans away from the dispenser. Anything that winds up touching the dispenser during the wash cycle can cause the dispenser door to stay closed. Run the dishwasher to see if this solves the problem.
  2. Step 2 Remove the front door panel according to your instruction manual, or find the manufacturer's instructions online, which will probably be in a PDF file. The panel is typically held on by 6 to 8 screws along the edge, which you can see when the door is open. With most models, you won't need to remove the screws at the bottom of the door, which are part of the hinge assembly.
  3. Step 3 Clean the detergent dispenser thoroughly from the inside of the dishwasher and the exterior side as well. Accumulated detergent and other material can interfere with the spring mechanism or halt the pivot action of the door. Use very hot water and a micro-sized brush. You also can use a mix of hot water and vinegar.
  4. Step 4 Most dispensers have a bimetallic strip or switch, attached by screws, which triggers the door release. With the front door panel removed, locate the switch, and push on it gently with a screwdriver until the dispenser door opens. You might simply need to adjust the alignment of the switch.
  5. Step 5 Purchase a new switch if re-aligning the old one does not fix the problem. Typically, these switches cost under $10. See Resources for a link to different manufacturers where you can buy the part.
  6. Step 6 Label the two wires connected to the switch so you can correctly reconnect them afterward, and then remove them from the terminals by holding the slip-on connectors --- not the wires --- and pulling firmly. Use a pair of needle-nosed pliers for a better grip. Then remove the switch from the dispenser by removing the screws holding it in place. Connect the wires to the terminals of the new switch, and attach the new switch to the detergent dispenser. Replace the door panel.
  7. Step 7 Run the dishwasher again to see if the switch replacement has done the trick. If not, decide whether to replace the entire dispenser according to the manufacturer's instructions, or call a repair technician.
Nov 14, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Do not know how to add dishwashing liquid to machine
Fill your clean, dry dispenser cup with detergent and close it.The water streams through the closed dispenser and comes out at the bottom of the dispenser. Make sure you have 120 deg f water coming to the dishdrawer and never put anything in that dishwasher that is to tall or comes up above the drawer when you start the dishwasher it has a lid that comes down and if it does not seal you will get an f1 code and it will require a tech.
Mar 31, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Detergent cup
Take the front panel off and you will see the dispenser tank. Remove and clean.
Jun 29, 2008 | Bosch 24 in. SHY66C02 / SHY66C06 Built-in...
Washing leaves spots
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you're using and adjusting your hot water heater's water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water. First you'll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, you can wash the glass with warm water and concentrated dishwasher detergent or use a high-phosphate detergent (such as Glass Magic) according to label directions. If film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature. See "Doesn't wash well," above. Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn't anything you can do to make it clear again. But you can avoid future etching by taking these steps: 1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don't use extra hot settings, such as "Power Scrub" and use "Energy Saver" dry cycle. 2) Adjust detergent amount. 3) Don't pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
Jan 18, 2006 | Hoover 24 in. DT999 Free-Standing...
Dishwashers Logo
76 people viewed this question
Top Jet Tech Systems Dishwashers Experts
Robert Marsolais
Robert Marsolais
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jet Tech Systems Dishwasher Expert? Answer questions, earn points and help others
