My washing machine fills, tumbles ,second phase fills then the fusebox trips this is happening on every programme i thought it might be something to do with the heater element but i tested it with a meter and it seems ok i then thought it might be a problem with the heat sensor so iv'e replaced it that was no good it won't even do a cold wash the only programmes that work are the rinse,spin and empty cycles any help in solving this would be much appreciated
SOURCE: Pre wash not happening
poss blocked filter which also controls your pressure system, on your machine I believe if the prewash ligbt is flashing it would indicate a blockage there
SOURCE: no heat on tumble dry programme. Display flashed F 13.
You need to replace the heating element for the dryer which is positioned on top of the outer drum. Remove the top cover of the machine and locate the heater.
SOURCE: dihwasher not working
I had a hotpoint engineer try to fix this type of problem.
He insisted that there was something stuck in the bottom of the pump.
Sure enough there was.
1. Unplug your dishwaser at the wall.
2. Remove the grill under the bottom rack.
3. Ensure that the filter is free from food and other obstacles and clean the filter.
4. Before replacing filter etc, get a piece of metal coat hanger wire and care fully insert it down the channel under the filter to free any lodged items. You may also see a small white impleller try to turn this with your finger or the coat hanger wire (this is the info from the engineer!).
5. replace filter and retry a wash.
This routine fixed or machine twice and will hopefully fix yours!
Don't forget to rate me!
fyi
The third time about 1 year later this occured again and even hotpoint gave up as they could not fix the machine. (after multiple visits). I think that the two flashing lights are were a red herring and the dishwasher had a separate intermitten fault. Hotpoint replaced the unit for a mimum charge. Callout + 40
SOURCE: Error lights.
This is a Circuit Board that is bad (main control).Do not repair this because the problem returns,and returns.
Hi Carol Noonan, I want to help you with your problem, but I need more information from you. What are the make and model of the washing machine?
