I have a problem with Fax. even though i have pass in fax test. my printer cannot auto answer and always detect 'phone off hook' but my phone line direct to printer and no others phone connected. HP already replace my printer and our local telecom provider also have check with my phone line..but the problem still happene.
SOURCE: HP G85 auto-answer
yeppers...same thing happens to mine. So, I simply set it to receive faxes manually now.
SOURCE: Will not grab documents
hi,
try this...
> unplug the power chord while the printer is turned on
> press and hold the # and 3 button on the printer at the same time and while holding it, insert the power chord.
> a semifull reset would be done
> after that try to fax.
thanks and regards
agnel
SOURCE: HP Officejet 5600 will not
connect the unit directly to the phone jack (wall), disconnect all other devices using the same phone line (telephones, answering machines only) (if you're on DSL, leave computers, routers connected).
go to faxzero.com and send a fax to your number. this way you'll be able to isolate if it's one of the equipment or a phone provider feature/service such as call forwarding.
SOURCE: Ricoh Aficio 350 change number of rings before fax answer
Can't be done..this fax can only operate on a dedicated line, and it picks up right away. Sorry.
