What can i do and is there a service manual for troubleshooting
SOURCE: New flatscreen Sanyo tv. Picture is to big for the screen
use the picture button to change the shape, Most likely you have it set to picture 3 which would cause that.
SOURCE: 3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Testimonial: "while we did not unplug the set, we let it sit for 2 days and we were able to turn it on by the remote & manually....does that still sound like P/S"
SOURCE: My Sanyo 26" flatscreen tv
hi,
if u using a cable connection direct to tv. then goto the setup menu and select auto tune function. wait till all the channel memories. for any further assistants contact me through fixya.
ok
SOURCE: Sanyo Dp53360 service manual
It was a little harder to find since you gave the wrong model number :)
Model number is DP55360. Here is the user's manual: http://us.sanyo.com/dynamic/product/Downloads/DP55360%20(348A-)-38838316.pdf
Internet User's Guide: http://us.sanyo.com/dynamic/product/Downloads/DP55360%20internet%20guide(358--)-34613941.pdf
Testimonial: "This solution was helpful. 1 Source: Phillips 51in tv rear projection power button blinking green Was this solution helpful? Yes "
