The machine will start eventually but it takes several attempts
It does sound as if it is the switch, since you can eventually get it going. Depending upon the age of the washing machine, you will need to decide whether another repair bill is worth it. I would look at the last bill and call the repairman for an estimate of current charges if you are sure it is the same problem. I don't recommend attempting ANY repair by an unauthorized person to a major appliance. Good luck to you.
SOURCE: Drum wont turn
our washing machine wma 31 has just stopped turning the drum and can not get it to work
SOURCE: F-08 error message on Hotpoint Washing machine
If it works fine with the heater off then i would say that fault appears to be element..the readings you get seem okay, put you meter onto megs and check, with wires off if you get electrical leakage between live and earth...Body....of element, it could be element is heating with no water in machine causing it to burn out..this is a problem with this machine...Wish you well
SOURCE: Hotpoint WDM 73 keeps tripping ringmain when powered on
I suspect that the problem is probably being caused by a fault on the dryer element or thermostat.
Remove the top cover and disconnect the heater, and see what happens..
If it does not trip, then prob is the dryer element or stat.
Hope this helps.
SOURCE: Hotpoint WMA46 door problem
From the symptons you describe, it could be a broken or weak spring in the door handle, which ca be fixed relatively inxpensively, that is where i would start, you can purchase one directly from hotpoint, or possibly a local repairer. if that does not cure the problem, then the odds are it will be a faulty programme module.
Hope this helps.
