Quantums are good chairs, but they have had some electronic issues. My first recommendation would be to see if you have the most current firmware update. This may take a tech with a newer programmer to do.
Quantums usually have a panel on the back of the chair that the joystick and other things plug into. Remove the panel and check the connections. Sometimes, the plugs work loose or begin to wiggle. I've had to secure a few with electrical tape to make sure they don't loosen.
SOURCE: power problem
Your batteries are probably done for. Get replacement batteries at any Auto Parts place.
SOURCE: My Pride Go Chair battery appears to discharge
Yes prob one of the batteries are bad, but you may want to replace both.
SOURCE: My dad has a mobility
Contact Roadrunner Mobility at 1-800-467-2668. They should be able to help you
SOURCE: Merits DL 52 i electric wheel chair, all leds flash 3 times.
The number of lights that are blinking indicate what the problem is.
Visit this site to locate the type on controller on your power chair and
you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer
for service. If your insurance purchased they power chair for you, they
may also cover the cost of repairs.
SOURCE: pride jazzy quantum 1420. working fine until
Could be in sleep mode try pressing the on/off button twice to get out of sleep mode if that doesn't work then you have a joystick problem and it needs to be replaced Hope this helps
