Question about King Kutter Pull Type Rotary Kutter 72in. Cutting Width, Model# P 60 60 P
Gear box loose how to tighten on king cutter 5ft brush saw. How do you get to the bolt heads? cannot get to it
  • King Kutter Master
  • 2,760 Answers
From underside???? wish it was a three point mount i'll bet
Posted on Sep 05, 2014
SOURCE:
09 Suzuki King Quad has oil in the radiator
Hi Joshua
Obviously a seal or head gasket is leaking oil to the water jacket.
Clean out the radiator and refill with water and see how long it takes to get oil back in water. Re Tighten head bolts if maybe loose.
Good Luck
Nov 02, 2014 | Motorcycles
How do you change blades on 5ft bush hog?
lift The brush hog up and place on blocks or other foundation that wont fall over. disconnect the power take off shaft from the tractor. Now look for two round openings in the middle of the deck one on ether side of the gear box (the thing on the brush hog that the pto shaft from the tractor hooks up to to make it spin there might be a slip clutch on the shaft but go to the box in the middle) Now turn the shaft till you see the blade nuts in the hole These could be castle nuts with a small carter pin locking them so they don't unscrew. Remove the pin and with a large socket set unscrew it from the bolt then knock the press fit bolt down and the blade will come off, do the same to the other blade if you need them both off. To put them back on use something under the blade and bolt to hold it up so you can start the nut then reverse the order and put everything back on. The blade bolt might be stubborn to get out just take something that fits through the access hole like a wood doll or long punch and drive the bolt down till it comes out as it is press fit and is jammed up to keep the bolt from turning, when putting it back on you will need to make it tight so the bolt can repress back in. Be Careful when reaching under to set the blade and bolt back in. There is not much you can mess up it is just a big nut and bolt Just make sure you put the blade on the way it came off if you do one blade or one at a time you can look at the other to see which way it goes.
Oct 02, 2014 | King Kutter Rotary Tiller Pto Bush Hog...
How to service gear case on Honda435u brush cutter
Under normal cercumstances you don't require to service this, except greasing the gears and that is done as... There is a L key bolt on the right side of the pipe (you should own a L key set) above the blade you are useing,,open the bolt in the normal direction means anti clock wise than insert grease in to the opening till it doesn't start coming out by it self that means its full. Replace the bolt but don't tighten it too hard because it can create problem to open next time.when you now run the brush cutter it will run smooth. On ther hand if there is any other problem than this like gears are broken or something than replace the entire assembly
Sep 24, 2014 | Garden
Why won't it turn over?
Have you checked the battery?
Aug 27, 2014 | Cars & Trucks
What socket do i need for removing the caliper bolts on a 2005 road king custom
The bolts are metric and use a 10mm 12 point head.
To re-install caliper:
1, Loosely install long caliper mounting bolt into upper
lug of front fork leg.
2, Install short caliper mounting bolt into lower lug of
front fork leg. Tighten lower mounting bolt to 28-38
ft-lbs (37.9-51.5 Nm).
3, Tighten upper caliper mounting bolt to 28-38 ft-lbs
(37.9-51.5 Nm).
4, Tighten pad pins to 180-200 in-lbs (20.3-22.6 Nm).
May 03, 2014 | 2005 Harley Davidson FLHRS - FLHRSI Road...
Gear box filler plug
glue or weld the head of a bolt to it.then use two nuts on the bolt tighten both of them now a ring spanner on the first nut as is held by the second nut.
Dec 16, 2013 | 2005 Nissan Sentra
Arbor stuck on gear head/bc26
I have the same problem. Any solution?
Apr 20, 2010 | Ryobi Garden
How to tighten handlebars on a harley davidson 1997 road king?
If it is the clamp that is loose, remove the riser cover and tighen the 4 allem head screws. If it is the riser base that is loose, turn your bars to the left, look under the triple tree and you will see a large bolt head, one one each side, use a socket and tighten, swing the bars to the right, and repeat on the other side.
Happy riding!
Paul
Mar 12, 2010 | Harley Davidson FLHRC Road King Classic...
King Kutter Pull Type Rotary Kutter 72in. Cutting Width, Model# P 60 60 P Logo
264 people viewed this question
Top King Kutter Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a King Kutter Tool and Hardware - Other Expert? Answer questions, earn points and help others
