SOURCE: 2001 jeep grand cherokee 4.0 engine shuts off
it is possable/likely a bad ECTS (engine coolant tep. sensor), this can cause the injectors to allow to much fuel into cylinders and cause a low compression and or flooding situation, good luck, marty
SOURCE: 1997 Jeep Grand Cherokee when starting sometimes
I had a similar problem with a 2001 Mercury Grand Marquis and it ended up being a bad fuel filter. But it could be a number of different things.My suggestion would be to check the vehicle on-board computer trouble codes and go from there. Good Luck.
SOURCE: I HAVE 95 JEEP GRAND
Had similar problem with 96 Jeep 4.0L engine. Tracked it down to the connector for the distributor pickup. Spliced in another connector and hasn't stalled since. Also, have you had any codes? Easy way to check on Chrysler products: turn key on, off, on, off, on (not starting) and watch the 'engine light' on the dash. It will flash off/on. Count the flashes with short pauses between and longer pauses between code. When you get a 5 count and 5 count, that is the end. This may also help
if this is a 5.2 or a 5.9 its a bad cam sensor. its located just under the cap and rotor and its a round plastic ring with a wire harrness. you should have a code come up
