SOURCE: sidekick 3 dropped in a cup of water. Water got into screen.
Is the screen blank all the time?
If you look really hard can you see the items on the screen but they are really dark? If so the back light for the lcd may have burned out.
Take a look at the following site for instructions on disassembly.
http://www.gsfx.org/disassembly/index.htm
If you feel comfortable with it, you can easily replace your own.
A new lcd runs about 50 dollars shipped. If you buy it from ebay, they
will usually come with instructions and the screwdriver you need. A T6
torx driver is the type needed.
Sidekick LCD screens
Good job on drying it out and pulling the battery. Thats the best thing you can do when you get it wet!
SOURCE: Wet phone has black screen
You took all the right steps, including the rice. Unfortunately, even the rice method doesn't always catch the moisture before it does it's damage. The next step is to take the phone back to the store where you purchased it and have them see if it is salvageable. The other thing to check is where you stand with your contract. You may be able to replace the phone by extending your contract. good luck.
SOURCE: My screen on my nokia 5310 is black and white
if you have electronic cleaner clean the phone or you can rinse it in water wait a day for it to dry and it might work
SOURCE: wet cell phone-blank screen
Well it depends on the type of screen you have in the phone. Some have edges that can split open and lose the fluid that projects the picture so your best bet is to just replace the phones screen, if every thing else works fine
SOURCE: phone got wet stuck on download screen & vibrates
the phone needs service, when it got wet it damaged the mother board of the phone.
