My flymo qs 46sd starts fine and runs but wont idle and has no revs but it worked fine last week.?
Does it have a throttle cable fitted?? you really dont need an idle as as soon as you release the opc or dead mans handle it will cut out anyway. engine should be reving at 3000-3100 rpm. if this mower has a briggs and stratton engine fitted, remove the air filter and check the spring and linkege is still attached to the air vane govenor
SOURCE: what oil do i use for my Flymo self propelled 46SD Q46SD
Most lawn mowers use SAE 30. Look on the dip stick and it should be printed on there.
SOURCE: My flymo gl47 does not get up to max revs,any
you can adjust the rpm on the carb underneath the fuel tank
