Mine has not been used in a long time. parts are missing like the 9.6v dc plug,the 2 hour battery,tv adapter,and it has2 chargers(1 that mounts the back of the cam which my one battery does not fit,and another larger one the battery fits but only displays the red power light).any ideas on how to rig it for power to see if it even works before i spend money on this hand-me-down relic
SOURCE: RCA prov712 battery will only last 5 minutes
Be sure to charge for AT LEAST 14 hours on the new battery, even if the charger light goes out - it's still trickle charging. It's normal for most camcorders to auto-shut off after 5 minutes, if it's not recording. But if your batt light comes on, the problem is probably with the battery.
SOURCE: How do I hook up a 75 ohm cable to the unit?
You need a simple Male RF adapter to a 300 ohm connection. Go here to see the picture http://www.showmecables.com/productDetailsPopUp.asp?idproduct=1889 and print it out and take it to radio shack and show the salesman there. they will have this part for you for sure. Good Luck
SOURCE: can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
SOURCE: rca d52w19
You can change the HV splitter first,then change the flyback
transformer, if necessary.......Do be careful with part number
of transformer....check the drawing number on it ......10756 =
259296.......10799 = 265409......as examples..........
I can check on that for you based on your info................T.
SOURCE: No Display
Underneath the black battery, when you take it off to charge, there is another small battery compartment it holds a round battery about an inch in diameter. try replacing it. that might be the problem. hope it works out for you.
