Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
A
Anonymous Posted on May 20, 2014
KOHLER SMOKES STARTS UP ONLY HOT OR COLD,NO SMOKE WHEN RUNING
2005 JOHN DEER 600HRS.RUNS GREAT ,BUT SMOKES ON START UP.
J.D. Browning
Level 3:
  • Master 2,760 Answers
  • Posted on Jan 30, 2015
J.D. Browning
Master
Level 3:
Answers
2760
Questions
0
Helped
1013805
Points
6696
Look down inside air cleaner before starting next time , if theres more than a finger full of motor oil in there then your head gaskets are going
Hyundai atos 2008. was serviced and now it smokes, especially when it has been standing for a while. never did this before the service. When it stands for a while it starts smoking blue white smoke.
What is the problem if i start my car if its cold and it smokes blue white smoke but if engin is hot it stops smoking but valve tem seals have been done and there is no play on pistons
1helpful
John Deere 214 with Kohler K321
Check carby is not to rich,"mixture screw" check for fuel blockage on fuel tap.
Cold start blazer
change your MAP sensor and clean the IAC valve
J power and smokes white
Possibly a head gasket problem (as the head heats up it warps slightly, allowing coolant to seep into the cylinders, which is the source of the white smoke--steam) Is the motor using coolant?
2answers
Ford Focus 2005 - cold start backfire - runs great after 5 mins, when hot
White Smoke out the exhaust, is usually a sign
of coolant & most likely the start of a bad head gasket
At this point your use of the car should be curtailed,
to prevent any further damage
You should not use the car at all, until all issues are
diagnosed & resolved
Plan on using other means of transportation
SL2 1996 will not start unless I hold throttle down. Starts and smokes a lot wit h blue smoke and will not idle. Runs great at 2000 to 3000 RPMs
Itt's possible that you could have one or two injectors leaking, Start by removing you spark plugs and see if thier with gas
7helpful
3answers
1helpful
I have a John Deer L155, just tuned it up new
This problem sounds like you may not be getting fuel. This tractor may have a fuel shut of solenoid in the carb float bowl. if this is the case... after then engine warms up and the solenoid gets hot it may have a open in the coil and will not open the needle valve in the carb until it cools off. Easy way to check this is when it does not start for you turn the ign key on to run and then back off you should here a clicking sound if the solenoid is working. If you dont hear a clicking sound the solenoid is probably bad... you can prove this by waiting for it to cool off and trying the same thing if you hear the solenoid valve actuating then the solenoid is bad
Aug 15, 2009 • Garden
Top Kohler Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
