Sony Handycam HDR-HC3 HDV Digital Camcorder Logo
A
Anonymous Posted on May 20, 2014
Sony dcr-pc5e reset - Sony Handycam HDR-HC3 HDV Digital Camcorder
1 Related Answer
Anonymous
  • 35 Answers
  • Posted on Aug 10, 2010
SOURCE: I need to down load
  1. look at manufactuers website
  2. look on google (not recommended
tip
Convert/Import Sony DCR-SX/SR/HC/DVD Series to Mac, iMovie, FCP
As we known, Sony DCR series camcorder includes Sony DCR-SX, Sony DCR-SR, Sony DCR-HC, Sony DCR-DVD, Sony DCR-TRV, Sony DCR-VX, etc, and most of Sony DCR camcorders record video in SD MPEG-2 such as some Sony DCR-SX series, Sony DCR-SR series, Sony DCR-DVD series.
Some Popular Sony DCR Camcorder Series in the following:
Sony DCR-SR: SR40, SR42, SR60, SR68, SR82, SR87, SR100, SR200, SR300, SR45E,SR65E, SR87E, SR85E, SR220E, etc.
Sony DCR-SX: SX40, SX44, SX60, SX63, SX83, SX34E, SX40E, SX43E, SX46E, SX60E, etc.
Sony DCR-HC: HC35, HC26, HC28, HC62, HC40, HC21, HC52, HC24E, HC38E, HC54E, etc.
Sony DCR-DVD: DVD650, DVD108, DVD92, DVD850, DVD403, DVD505, DVD610E, DVD710E, etc.
Due to Sony DCR video cannot be directly imported to iMovie, Quicktime, iTunes, FCP, Adobe Premiere Pro and some other popular devices, if you want to import your Sony DCR Handycam SD video to Mac for enjoying or further editing with iMovie, FCP, FCE, etc, the first step for you to do is to convert these Sony SD video to MOV, MP4 for Mac, then you can import converted Sony DCR video to iMovie, Quicktime, iTunes, FCP on Mac for enjoying or editing.
To convert Sony DCR series video to Mac, Sony DCR Video Converter for Mac is the best software to transfer these Sony DCR SD MPEG-2 video, Sony AVCHD MTS, M2TS files, and some other camcorder videos to MOV, MP4, MPEG, 3GP, M4V, etc on Mac. Besides, you can also convert and import Sony DCR SD video to iPad, iPod, iPhones (including iPhone4), PSP, Blackberry, and other mobile players.
How to Convert Sony DCR video to Mac OS for further editing with iMovie, FCP, etc?
Step1: Add Sony DCR Video on Mac
Click "Add File" to upload your chosen Sony DCR video to Mac AVCHD Converter after you launched it.
Step2: Set Output Video Format for Mac
Click "Profile" to open the Profile drop-up list to select MOV, or MP4 as output video format for Mac OS, Quicktime, iMovie, FCP, FCE, etc.
Step3: Convert Sony DCR Video to Mac OS
Press the "Start" button to convert Sony DCR SD video or AVCHD MTS/M2TS files to Mac. After conversion finished, you can enjoy converted Sony DCR video on Mac or edit these videos with iMovie, FCP, FCE, iDVD, etc.
Related: How to Convert and Edit Canon VIXIA HF Series to Mac?
How to Convert and Edit Panasonic HDC Series to Mac OS?
on Oct 26, 2010 • Computers & Internet
Download sony digital video camera dcr pc5e driver
Search box. Type in details. Loads of info.
I want to restore my Sony dcr-hc62e camera to factory settings.?
Pleaser press the reset button behind the LCD panel to reset the Camcorder to factory settings..
9helpful
2answers
Sony dcr-hc26 touch screen does not work
If the touch screen of the Camcorder is not working, pleasefollow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
dcrhc26%20reset%20button.jpgdcrhc26%20reset%20button.jpgmoz-screenshot.pngmoz-screenshot-1.pngrsshajan_3.jpg
Note: 8 represents the reset button on the above figure.
If the issue persists again, please perform LCD screen Calibration and check ifthat helps.
Please follow the steps below to perform the LCD Calibration
If the issue persists again, service is required.
I hope this information will help you to resolve the touch screen issue of theCamcorder.
2helpful
I need to down load drivers of mini DV sony DCR-PC5E
Problem with touch screen
Try pressing the Reset button on the Camcorder. If the issue persists, try power resetting. To power reset, remove the battery of the Camcorder and press and hold the power button for 30 seconds and reinsert the battery after one minute and check the operation. If the issue still persists, the service is required.
Sony DCR-PC5E showing low battery constantly, but battery appears to be OK.
Initially, I would suggest replacing/charging the batteries. This is to eliminate the possibility that is a battery/charging issue. Additionally, pls try to verify that the battery contacts both on the Sony and the batteries themselves are clean. You may need to scrape them off to assure positive contact. Further on the camera's battery terminals, you may need to slightly bend them (or stretch if spring type) to provide more pressure in the contacts (this is of course if the design will allow you to).
Should the above be not corrective, then in most likelihood, it is an internal electronic error.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 31, 2008 • Cameras
Data code problem pleeeeeeese heeeelp......
Here are some programs that might help you with your problem : DV Sub Maker (Freeware) from Mike Laba aka Krong makes DVD subtitles from DATECODE in SUB or SST format which can be used in Scenarist and ReelDVD. DV Date Time Changer can change the DATECODE. And the test version of Play DV shows the DATECODE when playing DV AVI files. See http://video2dv.com/ DV Date, (old name DVRecDate) a shareware Adobe Premiere plugin from Ilia Topolnitski stamps DATECODE in videos. A DVD Subtitler (also shareware) exists too! See http://dve.teletex.ru/
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
