Fuji Instax 210 Wide Polaroid Camera 80 Films Pen Logo
A
Anonymous Posted on May 20, 2014
Ball joint removel tool - Fuji Instax 210 Wide Polaroid Camera 80 Films Pen
1helpful
How to change a Xantia bottom ball joint
Depressurize the hydraulic system. Jack the front and put on jack stands (both left and right side). Remove wheels. Slacken and unscrew the ball joint nut partially. Release ball joint from knuckle using a proper separation tool. Once dislodged, remove ball joint nut and pull out strut/knuckle away from lower arm. You may need to push down the arm with a lever. Remove dust cover from the ball joint. The ball joint can be removed by unscrewing it using a tool that locks into the notches on the sides of the ball joint. Install new one by screwing in the ball joint back into the knuckle.Tighten well.
Need pictures and procedure 91 Ford pickup F250 twin I beam ball joint replacement.
Wheel Spindle, F-150, F-250, F-350
Removal
  1. Raise the front of the vehicle and install safety stands.
  1. Remove the wheel and tire assembly. Refer to Section 04-04 .
  1. Remove the disc brake caliper (2B120) from the rotor and wire it out of the way. Refer to Section 06-03 .
  1. Remove the dust cap, cotter pin, nut retainer, nut, washer and front wheel bearing (1216).
  1. Remove the rotor from the front wheel spindle (3105).
    Item Part Number Description 1 606085 Clamp Bolt 2 3B404 Camber Adjuster 3 800895 Nut 4 800937 Nut 5 3049 Front Suspension Upper Ball Joint 6 3050 Front Suspension Lower Arm Ball Joint 7 3105 Front Wheel Spindle 8 642569 Cotter Pin 9 3304 Steering Sector Shaft Arm Drag Link 10 383489 Nut 11 3001 Front Axle Assembly 12 388727 Bolt A - Tighten to 77-103 Nm
    (57-75 Lb-Ft) B - Tighten to 68-92 Nm
    (50-67 Lb-Ft) C - Tighten to 113-153 Nm (83-112 Lb-Ft) D - Tighten to 340-460 Nm (250-339 Lb-Ft)
  1. Remove bearing cone and roller (1201) and wheel hub grease seal (1190). Discard the seal.
  1. Remove front disc brake rotor shield (2K004). Refer to Section 06-03 .
  1. Disconnect the steering linkage from the integral front wheel spindle and spindle arm by removing the cotter pin and nut and then removing the front wheel spindle tie rod from the spindle arm with Tie Rod End Remover TOOL-3290-D or equivalent.
  1. Remove the cotter pin and castellated nut from the lower ball joint stud.
  1. Remove the nut from the axle clamp bolt and remove the bolt from the axle.
  1. Remove the camber adjuster from the upper ball joint stud and axle beam. If required, use Ball Joint Removing Tool D81T-3010-B or equivalent to remove adjuster.
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use a pickle fork to separate the ball joint from the axle as this will damage the seal and the ball joint socket.
    Strike the inside area of the axle as shown to pop lower ball joints loose from the axle beam.
  1. Remove the front wheel spindle and ball joint from the axle.
Ball Joint, F-150, F-250, F-350 SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number U-Joint Tool T74P-4635-C Ball Joint Remover T94T-3010-AH
Removal
  1. Remove the front wheel spindle (3105) and ball joint assembly from the axle. Refer to Wheel Spindle, F-150, F-250, F-350 in the Removal and Installation portion of this section.
  1. NOTE: Lower ball joint must be removed first.
    Install the front wheel spindle in a vise and remove the snap ring from the lower ball joint.
  1. Remove the lower ball joint from the front wheel spindle using U-Joint Tool T74P-4635-C and Receiver Cup D81T-3010-A5 or equivalent for F-150. Use Ball Joint Remover T94T-3010-AH for F-250 and F-350.
  1. Turn the forcing screw clockwise until the ball joint is removed from the front wheel spindle.
  2. CAUTION: Do not heat the ball joint or the front wheel spindle to aid in removal.
    Assemble U-joint tool and cup on the upper ball joint, and turn forcing screw clockwise until ball joint is removed from the front wheel spindle.
    Installation
    1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not heat the ball joint or axle to aid in installation.
      NOTE: Upper ball joint must be installed into the front wheel spindle first.
      NOTE: Individual ball joint tools are included in Ball Joint Adapter Set D81T-3010-A or equivalent.
      To install the upper ball joint, assemble C-frame assembly, Ball Joint Receiver Cup D81T-3010-A5 and Installation Cup D81T-3010-A1 and D81T-3010-A3 or equivalents inside cup D81T-3010-A4 or equivalent in position on the front wheel spindle.
    1. Turn forcing screw clockwise until ball joint is seated.
1helpful
Broken lower ball joint need tips on removel of the broken one and installation of new one.
It is difficult and probably not advisable to remove the broken ball joint since I think it is riveted in place, you can drill them out as the replacements come with threaded studs, and use a ball joint fork to drive it out. Most people find it is better to replace the lower control arm, it comes with a ball joint attached. You will then need an alignment.
NEED TO REPLACE OLD BALL JOINT WITH NEW ONE PLEASE EXPLAIN PROCEDURE
You will need a ball joint seperator tool and a large hammer. With the proper tool this is easy. Seperate the ball joint with the tool and hammer and replace with the new ball joint.
Ball joint repair and how do you do it
To perform the following procedure, the lower control arm must be removed from the vehicle. Refer to Removal And Installation for that procedure.
  1. Using a screw driver or other suitable tool, pry the seal boot off of the ball joint assembly
  2. Position receiving cup, Special Tool 6758 to support lower control arm when removing ball joint assembly. Install Remover, Special Tool 6919 on the top of the ball joint assembly.
  3. Using the arbor press, press the ball joint assembly completely out of the lower control arm.
NOTE: When installing ball joint in lower control arm, position the ball joint in control arm so notch in ball joint stud is in the direction shown. This will ease assembly of the ball joint to the steering when installing pinch bolt.
  1. By hand, position ball joint into ball joint bore of lower control arm. Be sure ball joint is not cocked in the bore of the control arm, this will cause the ball joint to bind when being pressed into control arm.
  1. Position control arm with installed ball joint, in an arbor press with Receiving Cup, Special Tool 6758 supporting the lower control arm. Then center Installer, Special Tool 6908-4 on the bottom of the ball joint
  2. Carefully align all pieces. Then press the ball joint into the lower control arm until it is completely seated against surface of lower control arm. The ball joint is correctly installed when there is no gap between the ball joint and the lower control arm. Do not apply excessive force against the ball joint or the lower control arm.
  3. Install a NEW seal boot by hand as far as possible on the ball joint. Installation of the seal boot is to be with the shield positioned as shown.
CAUTION: Do not use an arbor press to install the sealing boot on the ball joint. Damage to the sealing boot will occur if excessive pressure is applied to the sealing boot when it is being installed.
  1. Place Installer, Special Tool 6758 over seal boot and squarely align it with bottom edge of seal boot. Apply hand pressure to Special Tool 6758 until seal boot is pressed squarely against top surface of lower control arm.
CAUTION: A replacement ball joint is not pre-lubricated. Properly lubricate the replacement ball joint using Mopar Multi-Mile grease or an equivalent. Lubricate ball joint after seal boot is installed but prior to top of seal boot being pushed down below notch in ball joint stud. Air must vent out of the seal boot at notch when grease is pumped into ball joint, failure to do so will balloon and damage seal boot. Do not over grease the ball joint, this will prevent the seal boot from pushing down on the stud of the ball joint.
CAUTION: After the ball joint is properly greased, clip the end of the grease fleeing off below the hex. The ball joint seal boot is non-purgeable and further greasing is not required and can result in damage to the seal boot.
  1. Reinstall lower control arm on vehicle.
1helpful
How to remove upper and lower ball joins on a 4x4 bronco full size 1986
For Lower & Upper Ball Joint Step by Step :
For That you use a C-clamp style ball joint press to remove the ball joint from the suspension arm-note the location of the receiver cup ! For installation of the ball-joint, use the same tool when pressing the ball joint into the suspension arm-again, note the location of the receiver cup.
Step by Step :
  1. Raise and support the vehicle safely, with jackstands.
  2. Remove the spindle and the ball joint assembly from the vehicle.
  3. Remove the snapring from the ball joint. Using a ball joint removal tool, remove the ball joint from the spindle. Do not heat the ball joint or the axle to aid in removal.
  4. Installation is the reverse of the removal procedure. Torque the ball joint stud nut to 85-110 ft. lbs. for 1983-89 Ranger and Bronco II.
    Please Rate, Thank you !
HOW TO PUT BOTTOM BALL JOINT
Requires 2 jacks, 1 under ball joint suspension, remove wheel. Remove ball joint nut, using a pickle fork tool separate wheel spindle from ball joint. With second jack carefully raise vehicle. Press out ball joint with tool and press in new and install in reverse instruction order.
How to replace lower left front ball joint ?
Removal & Installation NOTE This procedure requires the use of the following special tools: J 9519-E Lower Ball Joint Remover and Installer, J 34874 Booster Seal Remover/Installer, J 41435 Ball Joint Installer, J 45105-1 Ball Joint Flaring Adapter and J 45105-2 Receiver.
  1. On 4WD vehicles, remove the wheel center cap and drive axle nut.
  2. Raise and support the vehicle.
  3. Remove or disconnect the following:
    • Tire and wheel
    • Wheel hub and bearing, if necessary
    • Outer tie rod retaining nut
    • Out tie rod from the steering knuckle using a suitable puller
    • Brake hose bracket retaining bolts and bracket
    • Upper control arm-to-steering knuckle pinch bolt and nut
    • Upper control arm from the steering knuckle
    • Lower ball joint retaining nut
    • Steering knuckle from the lower control arm using a suitable ball joint removal tool
    • Steering knuckle from the vehicle
    • Lower ball joint flange with a chisel
  4. Install tools J 9519-E and J 34874 to the lower ball joint, then use those tools to remove the lower ball joint from the lower control arm.
To install:
  1. Install or connect the following:
    • Lower ball joint to the lower control arm, using tools J 9519-E, J 41435 and J 45105-2
  2. Remove the tools from the lower control arm.
    • Tools J 9519-E and J 45105-1 to the lower ball joint
  3. Flare the lower ball joint flange with J 9519-E and J 45105-1, then remove the tools from the lower ball joint.
    • Steering knuckle to the lower control arm
    • Lower ball joint retaining nut and tighten to 81 ft. lbs. (110 Nm)
    • Upper control arm to the steering knuckle
    • Upper control arm pinch bolt and nut and tighten to 30 ft. lbs. (41 Nm)
    • Brake hose bracket to the steering knuckle
    • Brake hose bracket retaining nuts and tighten to 7 ft. lbs. (10 Nm)
    • Outer tie rod to the steering knuckle
    • Outer tie rod retaining nut and tighten to 33 ft. lbs. (45 Nm)
    • Wheel hub and bearing, if removed
    • Tire and wheel
  4. Lower the vehicle
    • Drive axle nut, if 4WD, and tighten to 103 ft. lbs. (140 Nm)
    • Wheel center cap, if removed
  5. Check the front wheel alignment.
18helpful
4answers
How do I replace the upper ball joints in my 2002 Ford Explorer?
The upper ball joints are replaceable without replacing the control arms. Use Moog K80008 ball joints and a ball joint press.
1helpful
Replacing a '98 Grand Cherokees ball joints
The only parts you need are the ball joints, upper and lower, a total of 4, if you need all 4. As far as tools, you'll need wrenches, a removal and installer tool, the ball joints are pressed into the control arms, and a ball joint to steering knuckle seperator tool.Without those special tools, you will never get them changed, if you do it yourself.
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
