SOURCE: reseting drum cartridge on xerox 3535
Yes I m drincopy from Kosovo i reseting oall drum for xerox
[email protected]
SOURCE: why my Fuji Xerox C525A color lazer printer print out not clear?
hi,clean corotron wires,drum unit & mirrors.send me result.
thank you.
SOURCE: Xerox WCP 416 , it showed message replace drum cartridge
Make sure the copy cartridges are fully in place all the way in. Check to be sure you have a "New" cartridge and the plastic cover has been completely removed from the toner hole. Sometimes they break and the toner will not go into the drum, causing problems.
Sometimes the side door is not closed with both hands and causes the spring plugger not to fully go in correctly. The plunger breaks and will not open the cover on the copy cartridge. This causes other mechanical binds you cannot see.
Extra care is needed when closing this side door.
On this machine sometimes you need a Xerox service call to make repairs and replacements of broken parts and to ensure the copy cartridge is functioning well.
It might not be related to the toner sensor but due to updates the machine software can be made to make changes in the way the machine operates.
This can only be done with a Xerox laptop computer by the Xerox service representative.
This will fix scanner timing problems at startup due to software update changes.
I don't mean to give you another information, but will help you decide if you need to make other decisions in the future.
Good luck.
SOURCE: my fuji xerox printer docuprint 203 A's drum
Press the button until all the lights are on..then let go the button, this will reset your drum counter.
SOURCE: Xerox - replacement toner cartridge problem
Not that I know of. Did you receive a chip with the toner? If not that chip would need replaced to reset the counter;
