Asrock 775S61 Motherboard Logo
A
Anonymous Posted on May 19, 2014
Clear CMOS Jumper JBAT
How do i clear the cmos on 775s61 i can not find any jumper indicating clear cmos or jbat1
Larry Welch
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 10 Answers
  • Posted on Jul 10, 2016
Larry Welch
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
10
Questions
0
Helped
4055
Points
24
Unplug the power cord and remove the RTC battery,quarter size watch type battery, for 10 min's.Put the battery back in and power it up.that should clear the cmos
2 Related Answers
Anonymous
  • 156 Answers
  • Posted on Mar 22, 2008
SOURCE: please help me
Hi
Check ASROCK P4i45GV R5.0 User Manual Page 17 - http://download.asrock.com/manual/P4i45GV%20R5.0.pdf
Note: Check Page 11 for the CLRCMOS0 location on the motherboard. From the picture CLRCMOS0 is number 18. You can locate CLRCMOS0 just below the CMOS Cell Battery.
Turn off the computer and unplug the power cord, then use a jumper cap to short the pins on CLRCMOS0 for 3 seconds. Please remember to remove the jumper cap after clearing the CMOS. If you need to clear the CMOS when you just finish updating the BIOS, you must boot up the system first, and then shut it down before you do the clear-CMOS action.
Regards
Mike
Anonymous
  • 21 Answers
  • Posted on Feb 16, 2009
SOURCE: Still will not boot
5~6 seconds of real time OR your estimate? perhaps you need to be more patient and let the motherboard current drain out sufficiently before trying to POST...
10 minutes is overkill I know but go off and do something else and then come back, a watched pot never boils eh?
Jumpers
Remove the jumper plug from the CMOS jumper (CLEAR CMOS) pins 2 and 3. Place the jumper plug on the CMOS jumper (CLEAR CMOS) pins 1 and 2 and wait approximately five seconds. Remove the jumper plug and replace it on the CMOS jumper (CLEAR CMOS) pins 2 and 3
Clear cmos jumper jbat pins
It is safer to remove the battery for two minutes.
If there is any residual charge in the system, and you use the jumper, you can damage the motherboard.
If you insist on using the jumper:
First unplug the power supply then push the start button to ensure the system has no charge, then change the jumper for about ten seconds.
Put the jumper back in the original position, plug the power supply back in, and you can boot he system .
2helpful
What is JBAT on Motherboard ?
Clear CMOS (JBAT)
if the computer will not boot move the jumper the 3 pins to the other side.
3answers
Video controller ( vga compatible ) required
Here is an official link for downloading the on board VGA drivers for MSI 865GVM3-V for windows xp operating system. In case thisd is not you op. system you can use this link to choose another one. Note that Windows 7 are not supported, if this is your case you have to try the compatibility option.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
P4M2PROP motherboard have power but not working???
The first step would be to clear the CMOS ram manually. To do this, you need physical access to the mother board.
- Make sure the power is off but do not unplug from power.
- Locate Clear CMOS (JBAT) Jumper. From above, lower right hand corner.
- Simply remove the jumper and put it back again.
- Power up.
- If problem persists:
- May be faulty ram
- If you have a video card installed, uninstall it and connect monitor to VGA port of motherboard. It could be a faulty video card.
- CPU could be over heating, clean with compressed air, check fans and CPU grease.
Hope this helps...
2helpful
Where is the clear bios jumper in my mis k9n6pgm-FI motherboard
JBAT1 is right next to the SATA2 connector.
Clear CMOS Jumper: JBAT1
There is a CMOS RAM on board that has a power from external battery to keep the data of system
configuration. With the CMOS RAM, the system automatically boot OS every time it is turned on. If you
use the JBAT1 (Clear CMOS Jumper) to clear data. Follow the instructions below to clear the
data:
You can clear CMOS by shorting 2-3 pin while the system is off. Then return to 1-2 pin position.
Avoid clearing the CMOS while the system is on; it will damage the mainboard.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Iā€™m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
Changed cpu multiplier from 17 to 19 now have blank screen on foxconn a88gmx, cant reset as cannot access bios
Try clearing the CMOS --- the down side is your lose all your setting --- the up side is you should be
able to access your BIOS
Clear CMOS Jumper: CLR_CMOS1 ( Located near CMOS battery )
The motherboard uses CMOS RAM to store the basic hardware information (such as BIOS data,
date, time information, hardware password...etc.). Clear CMOS data is the fast way to go back to
factory default when the BIOS settings were mistakenly modified.
The steps to clear CMOS data are :
1. Turn off the computer, unplug the power cord from the power outlet.
2. Remove jumper cap from pins 2-3, put it onto pins 1-2 to short them.
This will clear CMOS data.
3. Return the setting to its original with pins 2-3 closed.
4. Plug in the power cord to your computer and turn it on.
5. Go to BIOS Setup to configure new system as described in next chapter.
Clear Jumper on pins 1 & 2
1 ----
2 ----
Normal
(Default)
3 ----
CLR_CMOS1
  • Disconnect the power cable before adjusting the jumper settings.
  • Do not clear the CMOS while the system is turned on.
WARNING!
Jumper Diagram Definition Description
1-2 Set Pin 1 and Pin 2 closed
2-3 Set Pin 2 and Pin 3 closed
1helpful
Where is cmos reset jumper? Is it near battery,
Try
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/S.G_Aspire_M5640_M3640M1640_BOOK_VerC.pdf
page 77
label CLR CMOS 3 pin type 1-2 clear 2-3 normal
Ms 6541 bios will not clear it starts whitout jbat jumper
there are three pins on board area where the jumper is fix the jumper on the middle pin and the other unused pin and power the machine to clear cmos. rate this solution
Top Asrock Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
