Alps MD 5000 Thermal Printer Logo
A
Anonymous Posted on May 19, 2014
How do i resent the cr motor on my epson 7800
1helpful
What does "service req. - 00010005" on epson 4880 printer mean?
http://largeformatrepairs.co.uk/errors/epson/sp4880/00010005/
Quoting from the link above:
Service Call Error 00010005 CR Motor Out Of Step During CR Motor operation, there may be a case where the encoder pulse signal within the specified range is not input within a specified period of time or the pulse width is extremely long or short. In such a case, the CR Motor is judged to be out-of-step, so that this message is displayed and the printer stops operating.
This error occurs on the Epson Stylus Pro 4880 large format printer and is not a routine maintenance request.
tip
Epson Stylus Pro 3880
ERROR CODES CAUSES AND SOLUTION
1101
CR life error The CR scan path counter has reached a predetermined level.
(The end of life of the Ink Supply Tube)
Replace the Ink Supply Tube (INK, SYSTEM, ASSY) and reset the counter using the Adjustment Program. In addition, check the statuses of the CR motor (MOTOR ASSY.,
CR), the driven pulley, the Carriage Unit, and the Head FFC, if any abnormal noise or wear is found, replace the corresponding part(s) along with the Ink Supply Tube.1120
CR lock error The CR encoder failed to read the CR scale during a predetermined time period. Replace the CR encoder (BOARD ASSY., ENCODER, CR).
Replace the CR scale (SCALE, CR).The carriage unit does not operate due to a CR motor failure or some reasons. Move the carriage unit manually to check if it moves smoothly, and fix any abnormality.
Replace the CR motor (MOTOR ASSY., CR).1121
CR reverse error An abnormal operation (reveres movement) of the carriage was detected a predetermined number of times. Check the CR scale (SCALE, CR) for incorrect attachment, scratch, dirt, and fix any abnormality. Replace the CR scale (SCALE, CR).Replace the CR encoder (BOARD ASSY., ENCODER, CR).
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
How do i solve the cr motor problem of epson L110 printer?
CR motor is the carriage motor that moves the printhead side to side. ( as opposed to the PF motor that feeds the paper)
normally if you are have CR motor issues it is because of a piece of paper caught in the mechanism or a dirty or dry carriage rail.
move the carriage from side to side and see if you get a full range of movement. where is stops is where the paper is caught
to clean the carriage rail,
then just wipe all the old sticky grease and oil off the carriage rail and apply new lubricant.. epson have a special grease for their techs to use, but WD40 or silicone spray will work just fine.
Hello I hae a problem with my EPSON Stylus Pro 7800 it said maintenace request 0002 what I have to do for solving it
Its more of a fiddly job than a difficult one. Remove both end covers and drop down the tray which has the mainboard on. Loosen the tension on the carriage belt, remembering to check the belt tension on the scale before doing so, then remove the belt from the pinion of the motor. Unplug the connector for the motor from the mainboard, then undo the cable from all the various clips and pieces of tape up towards the motor. Then remove the motor and do it all again in reverse. Once its installed you will need to reset the counter to clear the error message.
11helpful
2answers
Epson styllus pro 7800 service call error 0001002d.. help
http://www.largeformatrepairs.co.uk/technical/maintenance-error-code-0001002d.htm
This happens when you let the "maintenance req. 0040" go for to long. The machine turns itself of to prevent damage.
Solution: Call epson and they will give you the reset code. Cannot find these codes online so if you do call please post instructions
Please rate the answer........
What does error code 1000060 for the epson 7880 mean?
1. Measure the resistance value of the CR Motor. (5.8Ω)
If the CR Motor is found in short mode, replace the C472MAIN Board at the same time.
2. By visual inspection, check the T Fence for any defect, such as damage or soiling, which can cause faulty reading by the sensor.
3. By visual inspection, check the harness of the CR Motor for any problem causing a short circuit to the frame.
2helpful
2answers
Change print head for Epson 7800
Probabily not worth the effort, Epson printers are really cheap to buy. Check their website in the Clearance section.
I have a Epson 7800 printer and need to get a new Apple Mac to run printer what would be the best Mac computer
i'm very sorry - this is the chat session that came up while my computer crashed
epson got the 7800 drivers for the latest mac's
Top Alps Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Jesse Walters
Jesse Walters
ADMIN Andrew
ADMIN Andrew
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
