I changed the batteries and now it keeps beeping at intervals of a minute. how can I stop it?
Remove four screws on back of unit,cut red wire going to round beeping speaker inside lower front faceplate. problem solved it will never beep again but still read temp correctly.
Worked for me, but the back buttons fell out and the small ones have to be replaced with the nubbies on the side over the post and the big one goes in with the notch facing the post one side.
There are two red wires. Cutting the top one stopped the outside transmitter reception and cutting the bottom one stopped all power. Repaired the wires found the manual which said to use the alert button to reset the upper and lower alarm limits at which time the alarm quit sounding. Pressing the alert button for three seconds and using the + and - buttons on the back of the unit to set upper and lower limits that met my needs. The manual is available athttp://www.manualslib.com/download/76935...
Good luck.
