SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
SOURCE: My Singer model 7466 will not pick up the bobbin thread.
I have a singer 7466 that won't sew. I have removed & replaced the bobbin case several times and re-threaded several times and it just won't work. I'm afraid I'll burn the motor! What do I do?
SOURCE: threading bobbin for singer 8734
NEW MACHINE, THE NEEDLE WON'T PICK UP THE THREAD. WHAT WRONG?
SOURCE: needle thread will not pick up bobbin thread
I finally had to take it in for repair at Sears
won pickup the bobbin thread Google SearchOne Point Advice Place a spool of thread on a spool pin.
One Point Advice Upper threading
- Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race.
Remove any loose threads or lint in the shuttle race.One Point Advice Installing a bobbin into a bobbin case
- You could be holding the needle thread too tight.
Hold the thread lightly to keep the end from going down into the shuttle.- The needle could be thread incorrectly.
Thread the needle eye from the front to the back.- The needle could be bent or improperly inserted.
Install a new needle with the flat side of the needle facing the back.- if this does not help you go to this link.
