Dell Inspiron 6000 Notebook Logo
A
Anonymous Posted on May 19, 2014
Why battery light flashes? - Dell Inspiron 6000 Notebook
NOEL
Level 3:
Top Expert:
  • Dell Master 8,606 Answers
  • Posted on Apr 06, 2015
NOEL
Dell Master
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2322151
Points
68630
Might be telling you to get a new one.it may not be holding its charge.
1helpful
Battery light flashing while driving
A flashing battery light while driving on your Polaris 700 EFI could indicate a problem with the charging system. Here are a few possible causes:
  1. Faulty alternator: The alternator is responsible for charging the battery while the engine is running. If the alternator isn't working properly, the battery won't receive a sufficient charge and the battery light may flash.
  2. Loose or corroded battery connections: If the battery connections are loose or corroded, the battery won't be able to receive a full charge from the alternator.
  3. Failed voltage regulator: The voltage regulator regulates the output of the alternator. If the voltage regulator fails, it can cause the battery light to flash.
  4. Failed battery: If the battery is failing, it may not be able to hold a charge even when it's being charged properly.
It's a good idea to have your Polaris 700 EFI checked by a professional mechanic to diagnose and fix the problem.
Mar 18, 2023 • ATVs
Have dell d610 battery light flashes 4 times red then one green, can't unplug
I would take note of the message you are getting and buy a new battery. I believe the red flashing lights mean that one or more of the cells in the battery are dying, and it's best not to turn off alarm lights like these. Did the battery hold charge for a longer period than one hour before you started to see the flashing light warning?
I have a jazzy 1121 power chair and the lights on the joy stik are flashing and the chair just stoped working
Doggy count the number of flashes ie 4 flashes pause 4 flashes if you are not getting any pauses
what lights are flashing the battery level lights or the speed lights? Are all the battery level lights flashing or there are 3,4,5,6 or 7 etc. lights flashing? if you are getting a pause between flashes the number of flashes will tell you the error. Your owners manual should tell what each code means. Hope this helps
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
23helpful
2001 CHEVY SILVERADO 2500HD BATTERY LIGHT FLASHES INTERMITTENTLY. NO PROBLEM WITH BATTERY OR WITH ALTERNATOR, BOTH OF WHICH TEST OK. NO PROBLEM WITH STARTING OR RUNNING, EXCEPT FOR THE FLASHING BATTERY...
2001 chevy silverado 2500hd battery light flashes intermittently. no problem with battery or alterntor. both tested ok. no problems with starting or running. voltage gauge reads just above 14. no problems with anything except battery light flashes. what could be the problem?
4helpful
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
3helpful
3answers
Battery light flashes 4times orange then 1green
We had the same problem. I figured out it was NOT the main battery, but the auxilary battery. The batter life WITH the auxiliary was 68% total, when I removed the 2nd battery the battery life shot back up to 98% AND the flashing orange / red lights were gone (both on the power source and off). I then replaced the auxiliary battery with a spar back up to make SURE that it was not a fluke and with the new backup battery firmly in place the lights still did not flash. Problem solved.
Battery Light Flashes Orange and Green
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
6helpful
2answers
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
25helpful
5answers
Hazard lights flashing
I have a 97 subaru outback and encountered the same problem. It is a security device on all newer subaru's. After changing or charging the battery, leave the negetive battery cable disconnected. Turn the key to the "on" position, then reconnect the negative terminal. This will stop the flashing.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
