Acer Aspire One Netbook 8.9" Notebook Logo
A
Anonymous Posted on May 19, 2014
How do I get the acer start button back
I have lost my Acer start button how do I get it back?
I have lost my wireless connection for my Acer Aspire 9300-5349
Hopefully you just shut down the "RADIO" and a switch will turn it back on.
Look on the far left hand sideand there is a row of buttons.
Just to the left of the CAPS LOCK button is a switch for the wireless to turn on and off.
When you get it back up and running download and save the instructions at this site.
http://www.manualowl.com/m/Acer%20Computers/Aspire-9300/Manual/114671
Hope this helps. Good Luck and God Bless
2answers
My Extensa 4620 empowering technology lost ,, I cannot open,, I need to reformat my Laptop,,
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=170 If you have lost it then you can re download it using the link above, If you want to re-format your computer you can use the ALT and the F10 button which will start the acer recovery to get to this please turn off your computer and then turn it back on holding the ALT button down and tapping the F10 button constantly this will activate the recovery and re set your computer to how you first got it, If i have helped please rate many thanks any further questions please ask. Kronoguy
My acer aspire M1610 was reformatted that the complete acer system including VGA was lost. How can I restore it by downloading through internet using free download?
Depends if you completed a Full Format on acer systems they have a back-up partition that contains a complete image of your hard drive that gets left un-touched the way to access this is by pressing ALT button and tapping the F10 button as soon as you turn it on keep on tapping the F10 button until you hear a constant beeping which means the buffer is full, if your computer has kept this partial it will tell you the process you need to do "on screen instructions" If your computer does not have this then you will need to either use a wired connection and downloading the drivers directly using this link http://support.acer-euro.com/drivers/downloads.html on some cases you wont have the ethernet controllers installed so its always best if you go to this site on a different computer and downloading the ethernet controllers on a removable memory stick to install it on the acer computer, as soon as this is done you will be able to use the acer site to download everything or the microsoft update to give you everything your computer has lost if you need further help use the comment below, Kronoguy.
Re-formatted acer 5610z to window xp and lost all acer controls! downloaded drivers from acer .com have wlan back but keyboard and disc drive are not working can you aid me please?
Some acer laptops will only work on certain Operating System if you have completely re-formatted and on boot up pressing ALT + F10 button does not activate the recovery partition then there might have been a fault during the initial installation and a fault occoured with the keyboard try re loading the laptop with the original software that came with the laptop,
6helpful
3answers
Acer 5517 mouse pad does not work. is it just a
First you should check if the button that enables and disables your touch pad is on. It's the button left to the power button.
7helpful
3answers
I need to reset my aspire 4315 series back to factory settings as it's not running properly, I've lost my hand book and can't remember what to do, could you possibly tell me what buttons to press when to...
First plug in the Notebook to a power socket with your adapter. Power on the Notebook and you will see the Acer splash screen. Immediately prell ALT and keep tapping F10 at the same time. It will take you to a screen where you will see "windows is loading files" or "starting acer recovery" it will ask you, how do you want to restore?" choose the option "restore to factory default" and click continue. It will go through the restore process and within 15 - 20 minutes it should finish the process. Your Notebook will be back to factory default settings and once again you can see the OOBE.
Hope you find this solution helpful.
We appreciate your comments and feedbacks, Please do not forget to leave your comments and ratings.
Thank you for choosing Fixya.
1helpful
2answers
Factory settings
Unlike other laptops, Acer laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer laptop to factory setting.
Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.
Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you have any other issue with your Acer laptop/desktop/Notebook, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
44helpful
13answers
Lost password to acer laptop
restart pc, when its booting back up, keep pressing F8 to get windows to start in safe mode, select safe mode, then windows will start with no drivers and large desktop icons, and an administartor account will be on the desktop.
Click on the admin account and go to control panel,click users icon, then click change an account, choose your account then click on delete password, restart pc and you will be able to log in
When you start a acer laptop up you can restore it back to factory condition by pressing a button i was wondring what that button was
I have 2 Acer laptops and neither have a restore option, usually you are prompted by Acer to make a backup disc as soon as you first boot it up and restore from that
3answers
Acer notebook/laptop 5920G(acer recovery management)
its dangerous to stop e rcovery process . the software may get corrupted . downlaod it again from e recovery support section of acer.com /. got oto add or remove programs and unistalll the program and try re installing it again . e recovery is a system acritical processs
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
