SOURCE: No Heat with new White Rodgers 1f85rf-275 Thermostat
The only way to resolve this problem and to distingush if its a thermostat issue on the system is to by pass the thermostat by putting a jumper between the hotwire and the heating wire if the system did run which happen most of the time. Call the HVAC technician to check your heating unit. Or call the White- Rodgers technical line at 18887259797 choose contrator division.
SOURCE: I have a White Rodgers thermostat series 1F78-151
- Check the wires on the terminals make sure that they are not loose
- Reset the unit by press time, up and down buttons make sure the systems is in on position.
- Set the system to cool then and lower the setpoint below room temperature. There may be up to five minute delay before the thermostat clicks in cooling. If the thermostat click this means its not a thermostat you have a problem with your cooling equipment call your installer. If the thermostat did not click the unit should be replaced.
SOURCE: need the wiring manual for a White Rodger
Please call the hometechline at 18002842925 to ask for a copy to be send to you, be ready with a valid emial address.
SOURCE: where is the model number of the thermostat
It's probably on a tag on the back of the unit, but you will probably have to remove it from the wall mounting to be able to read it. If it is the 1F85RF-275 model you can download a PDF version of the Operating Manual HERE. ___ *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Electronic Digital Multi-Stage Thermostat 1F83-261
