SOURCE: Removin CR1220 battery
There is the battery paned on the opposite side of data cable ......Remove the battery....you can take the help of manual too...its fully illustrated there..
SOURCE: My 2 yr old Powershot A560 is not accepting new
The battery you found (CR1220) is for the camera memory.IE time and date.Chances are the batteries that were installed are dead.Also check the contacts on either end of the batteries and clean if needed.
SOURCE: Canon powershot A590 IS. Always
That battery is for keeping the date and time settings when you take the regular battery out.
Testimonial: "Thanks. I won't go looking for another one of those then. Can this camera be saved?"
SOURCE: Just bought a Canon Powershot
I don't know where you bought the used camera but if you can, return it.
SOURCE: Hi Where can I find the
I looked for the 1220 and couldn't find it at Walgreens, Walmart, or Target. I'm going to try Radio Shack or a camera store. The battery is in the battery compartment, which contains the AAs, the memory card, and a little plastic cover that says CR 1220. You have to get a fingernail under the tab to pull the battery slot out. It's a tiny button-size. If you do a google search for Powershot 650 change battery cr1220, you'll find a site with a picture on it.
