They could have been a bad batch of batteries. Sometimes batteries aren't fully charged as they should. Try another batch. If the same thing happens go back to the store and request either a replacement or a refund since the clock should have a 2 year warranty
Used batteries from several different packs & a couple of different stores. Transmitter batteries hold up ok.Used batteries from several different packs & a couple of different stores. Transmitter batteries hold up ok.
In that clearly that clock is draining too much juice. Go back to the store with a proof you bought it there and request a replacementIn that clearly that clock is draining too much juice. Go back to the store with a proof you bought it there and request a replacement
You can't post conmments that contain an email address.
2.5 Watts sounds pretty high for an LED strip. If the batteries are paralled and the applied power is 1.5 Volts, then you will be pulling 1.6 amps - the batteries won't last long at all. The batteries are good for around 2500maH, (Milliamp hours). so figure you may get around 2 hours of life for the batteries.
We suggest Energizer Ultimate Lithium AA batteries to our customers in our camera shop, and they love them! They last a really long time, and are well worth the extra cost. We sell loads of them, and I've only had good comments back, not one bad one. I hope this helps. If it solves your problem, please rate my solution favorably. Thanks
Try using recomended batteries:
optional KODAK EASYSHARE Docks with 1 KODAK Ni-MH Rechargeable Digital Camera Battery KAA2HR; 2 Ni-MH batteries AA, 2 lithium batteries AA; 1 KODAK Lithium Digital Camera Battery CRV3; KODAK Ni-MH 2100mAh Battery Pack, KODAK Digital Camera Battery AA (ZR6); KODAK Alkaline Digital Camera Batteries AA; 3 volt DC input AC adapter
Mine usually last at least 6 months. But I am careful to lean it back slightly to make sure It's not touching the switch on the bottom, and I only use fresh energizer batteries.
Yes, there is definitely a fault with your camera.
You should be able to return it for a replacement.
I wouldn't experiment too much with batteries in this camera. batteries discharging this quickly are likely to overheat, causing unmentionable catastrophe.
Because digital cameras require such a high amount of current it is not recommended to use Alkaline batteries. My best suggestion would be to purchase rechargeable batteries that meet the following requirements.
(AA Rechargeable Batteries with a minimum of 1800mAh (or higher) Nickel MetalHydride 1.2V). or (Panasonic CR-V3 3V Lithium Battery)
