Blank screen , can hear that it is on Light flashes around the outside of screen every two seconds .
Check backlight
It could be the capacitors on the internal power supply. have broken down causing the screen to power up, run out of power, run out of power and turn off. then loop again. if you feel up to it, unplug the TV (Saftey first!) , take the back off the tv and have a look for any capacitors that do not have a flat top. if the top of them look or feel dome shaped, they need to be replaced. the ones that are "bulged" need to be replaced after that my guess would be that the TV would work fine. if you can or know some one who can solder this may be an easy fix. and cost less than 5 pounds good luck!
It most likely needs a zsus board, may need more than one board.
there is a chip on the zsus board, these chips are notorious for over heating and failing.
Open tv and look at power supply board. ...look for bulged caps...also controller boards could be blown if caps e blown
Any luck with ur problem.. I have the exact tv with the same problem
