Question about NorStar Meridian M7310 Phone
How to enable the ringer for a Norstar M7310?
SOURCE:
SOURCE: reset Norstar M7310 System Administration password
This works, i just did it today!!
Press Feature 985
Press the 9 Key
Enter RESETSMPSWD (73738767793) using the dialpad
Press YES
Once you have RESET the password, it reverts to the default.
See Below
If your system uses 2 digit extensions use 120000
If your system uses 3 digit extensions use 1020000
If your system uses 4 digit extensions use 10020000
Posted on Jul 03, 2008
SOURCE: nORSTAR m7310
To Log Into System Programming:
Press FEATURE * * 2 6 6 3 4 4
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
Press: NEXT Display will read: "B. General Admin"
Press: SHOW Display will read: "1. Sys speed dial"
Press: NEXT Display will read: "2. Names"
Press the SHOW Display will read: "Set names"
Press: SHOW Display will read: "Show set:__"
Enter the extension number of which you wish to change the name Display will read: "<##:name>"
Press the CHANGE softkey
Using the dial pad spell out the name Ex: If you need the letter K press the 5 key twice and then press # to confirm the letter. Continue until the entire first name is spelled. (note: you are limited to 7 characters)
Press: NEXT (if you fail to do this step, the name will not be saved!!!)
Press the RLS key
Hope this helps!
Posted on Jul 27, 2008
ynotphone
  • 192 Answers
SOURCE: How do I enable the company directory.
When you add a voicemail there is an option for DIRECTORY, say YES and that will set up a directory.
Posted on Mar 25, 2009
ynotphone
  • 192 Answers
SOURCE: how can i change my extension nuber (norstar M7310)
Sorry can you clairify this question...
-> You need a new extension number for your set?
-> You need a new extension on your set so you can see when they are on their phone?
If it is the first, there are many things that you need first, too much to explain at the moment. But you need to have the password and a template for your phone to make changes.
If it is the second, press:
- Feature * 0 and any button to find out what is on the button, look for an empty button or one that you want to overwrite,
- then RLS,
- press FEATURE * 2
- press the button where you want to add this new extension
- dial the extension of the new person
Voila you are done!
Posted on Jun 03, 2009
cnavarro
  • 2460 Answers
SOURCE: Have Norstar M7310 5 line phone 2 lines say they
You need to unplug something, just not the phone.
The two lines are probably conferenced together. Go find the gray Nortel cabinet and pull the plug on it.
Carl
Posted on Oct 30, 2009
Testimonial: "Thanks Carl, that worked."
How do I silence ringer M7310?
DND ,do not disturb, feature 85, or feature *80 to turn it down
May 06, 2014 | NorStar Meridian M7310 Phone
Turn ringer off
If you don't want it to ring at all you can set Do Not Disturb with Feature 85 and cancel it with Feature #85.
Nov 01, 2013 | NorStar M7310 Corded Phone
Norstar Meridian how to turn on the ringer
From the following web site:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Jun 15, 2012 | NorStar Meridian M7310 Phone
Incoming calls on Line 4 are ringing in personal office and mail line. I want it only to ring on Mail line . Our phone is a Norstar M7310. Thanks Sherrie
Enter Feature **2663444
Search through General Options until you find Ringing options.
Type in the extension number of your personal office.
scroll to line 4 choose turn ringer to off, and rls! Let me know if you need clarification on how to find Ringers in General Options.
May 20, 2011 | NorStar M7310 Corded Phone
Does auto answer feature is available on Norstar phones? if yes, how?. Thanks!
Yes in system programming, handsfree answer back must be enabled. There are several different phone system models that the M7310 phone works on. I need the model number of the phone system to give accurate programming directions.
Dec 07, 2010 | NorStar M7310 Corded Phone
How do I enable the company directory on the NorStar Meridian M7310 phone?
Feb 18, 2009 | NorStar Meridian M7310 Phone
Turn ringer on T7316
T7316 Manual
The volume control adjusts the handset, hands free, headset, and ringer volume. Someone may have fiddled with the buttons and turned the ringer down enough that it doesn't sound when a call is incoming.
Feb 12, 2009 | NorStar Meridian M7310 Phone
Nortel nt8b20af-03 Ringer volume
While a call is ringing in, use the volume bar
Dec 26, 2008 | NorStar Meridian M7310 Phone
How do i turn the ringer on my M7310 when external calls come in.
No where have I seen this documented in the Norstar Manual. Follow these steps:
Feature **266344
PW: 266344 (note that this is different pw than provided in manuals)
Terminal Sets- press top right button
Enter the extension to which you want to turn the ringer off
Press the top right button again three times until "Show Line" appears. Starting w/ the first line you want to turn off, enter the line and then "change" the status to "appear only", scan through your remaining lines and do the same steps. Remember to do all of the lines in your trunk.
Mar 14, 2008 | NorStar M7310 Corded Phone
NorStar Meridian M7310 Phone Logo
264 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
