One of the stabilizing rods inside the unit has come loose.
Two different symptoms, two different problems. The jumping can be reduced by installing a kit which includes an improved set of suspension rods. The F1 generally indicates a problem with the main control board
Sounds like a suspension problem causing an uneven spin balance, hence the jumping around.
Do u have the wash load balanced , I noticed this in a lot of washer problems , people just throw the cloths in the washer without balancing the load , this is something that must be done on every washer and load , you must do this every time you use it , hope this helps ,
