When I touch the pad it will click on that location and I can not move the mouse.
SOURCE: touch pad
well,it seems it is phisical problem.It is,in poor word,quite damaged.by steping on it some internal circuit might have been broken.
try to consult a specialized in leptops and hardware
good luck
SOURCE: laptop touchpad no longer does tap function
on the bottom bar by the clock, if your computer is newer there should be a small icon that controls your mouse. Simply right click on it and check the box "tap to click" or similar. Hope this helps!
SOURCE: synaptics touch pad, double tap not working
look in the sys tray, (lower left of screen) one of the icons will be concerned with the touch pad. you can turn on and of the double tap here. Sounds like yours is switched off.
SOURCE: touch pad
Hold "function (fn)", and "F7"... F7 should have a pic of a finger touching something...
SOURCE: Shortage?
There is a ribbon cable between the laptop & the screen. It sounds like you have a short in that cable. If you're not good with tedius electronic repairs, it would be best to have a shop repair it.
