Question about Logitech Radio Communications
How do i find and fix a broken wire thats not visible?
I have only 2 speakers and the subwoofer of the surround sound set logitech x530, and i tripped over the speaker wires as i was moving them across the room. now my (left?) speaker--- not the one with the volume control knob on it but the other one, has no sound.
    New Friend:
  • 34 Answers
Easier to just replace the cable.
Posted on May 19, 2014
SOURCE:
  • 5 Answers
SOURCE: No sound from my Logitech headset when on SKYPE
Maybe you need to select which Audio device you are using within Skype. It the Settings under Audio you should be able to select the default audio device that Skype talks to. If you set it to the USB headset, it might work properly.
Posted on Nov 10, 2007
SOURCE: Using Logitech headset & enable Skype to ring via Desktop speakers
I am having the same problem. Can anyone help?
Posted on Jan 24, 2008
SOURCE: Iam unable to call my frends through yahoo messenger by using logitech usb type headphones on mythoshiba laptop
Go into your sound controls and disable any other playback/recording hardware besides the logitech headset. Yahoo will still mute the headset but you can put the volume back up and start using it. Cheap work around but it works for me. I found that when using the headset, yahoo was trying to use my onboard sound devices instead of the headset.
Posted on Feb 20, 2008
  • 71 Answers
SOURCE: Apparent broken wire issue
I somehow think that it may not be the headphones, but rather the hardware in the computer...but then again if they are under warranty definetely get them fixed(if they are broken?...)
Good Luck!
Posted on Jun 12, 2009
  • 14 Answers
SOURCE: I have a short wiring in my left ear cup
Time for a new pair. If you are not handy with a sodering iron it is best to buy another set. Once the wires are broken inside the insulation the only thing that can be done is replace the wire itself. it is easy to break the wires inside the insulation twisting the cord, pulling or yanking the cord, along with blending the cord in a sharp bend acn damage this cords that they put on products today.
Posted on Sep 12, 2009
My Logitech X530..only the front -left speaker works. Thank you.
Sounds like you have not plugged it in correctly! Have you connected the 3 mini plugs from the speakers into the adapter and then the 2 phono leads into the other end of the adapter and then the 3.5mm headphone jack into your device?
Oct 25, 2014 | Logitech X-530 70-Watt 5.1 Surround Sound...
My left speaker has no sound unless i jiggle the cord right at the part where all 3 p;ugs turn into 1 cord. how do i fix it?
The wire inside the speaker cable is broken. You may be able to identify the exact point the wire is broken by bending the wire and unbending the wire. If you can locate the approximate location of the break, you could cut the broken section out then strip the wire, and reconnect. Best to solder if possible. Otherwise, you will probably need to replace the cable or buy a new speaker set.
May 19, 2014 | Logitech X530 5 Speakers
5.1 surround sound system
perhaps you wired the subwoofer backwards, you got the positive and the negative mixed up on one of the speakers
Dec 26, 2009 | Audio Players & Recorders
Only 2 of my speakers are working on my x530 surround speakers
you need a five channel sound card.
then all speakers will work.
dont forget to vote
Sep 14, 2009 | Logitech Z-5300e Surround Sound System...
Logitech X-530 Speaker Problem
SELECT CONTROLPANEL-SELECCT SOUN OPTION-SELECT SOUND SETTINGS-THEN SELECT 5.1 SELECT SPEKER. -THEN OK...
Sep 24, 2008 | Logitech X-530 Computer Speakers
Speacker problems
cheak sound card settinsg for 4 ch 5.1 output or in audio main menu ok
Feb 01, 2008 | Logitech X-530 Computer Speakers
Subwoofer and center box problems with Logitech X530
Hi Sainty,
this is just a shot in the dark, but have you attempted to play around with your sound driver's configuration? I'm unfamiliar with the newer Nforce stuff, but try looking around in the sound manager Nvidia uses. It sounds like it's been configured to swap speakers. (As an example, I'm using the realtek audio manager on an asus p5k-vm board myself, and the option shows up as "Swap Center/ Subwoofer Output" in my configuration.)
Dec 10, 2007 | Logitech X-530 Computer Speakers
Logitech x530 surround sound speakers sometimes make noise
Hi Nick
As you talk I remember a spair speakers I have a long time ago, brand Creative 5600, has a bad resistor inside the speaker SB, or board, you also check for bad cable at the back or static.
another thing is your volume control, sometimes if you down a few notch you may ...not feel the hit or beep, but check things first.
good luck
Nov 21, 2007 | Logitech X-530 Computer Speakers
Logitech speakers will only play on 2 speakers not 5
Liamog, i bought the exact same speakers and sound card, and i had the exact same problem as you. I tried for days to fix it and it turns out that its only a setting you have to enable in your sound card settigns. If you go into your EAX console for your creative sound card you will find a thing that sams CMSS 3D, and all you have to do is select the button that says Enable CMSS 3d surround. I hope this will fix your problem. Alex.
Nov 11, 2006 | Logitech X-530 Computer Speakers
Radio Communications Logo
109 people viewed this question
Top Logitech Radio Communications Experts
Ekse
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
