Bosch 24 in. SHX99A15UC Stainless Steel Dishwasher Logo
A
Anonymous Posted on May 19, 2014
Bosch dishwasher error code h01? Won't start.
3 Related Answers
Anonymous
  • 109 Answers
  • Posted on Aug 23, 2009
SOURCE: My bosch dishwasher starts then stops with a error
I have had a few people with the same my advice is to tell the comp. you bought it from it is under warrenty
Anonymous
  • Posted on Sep 19, 2011
SOURCE: Display has error code h01
h:01 means 1 hour delay. Press the delay button repeatedly to get to h:00 then hit start.
Bob Butcher
  • 34 Answers
  • Posted on Nov 17, 2013
SOURCE: What is error code 2H
My Bosch dishwasher did the same thing. When the wash cycle starts, the dishwasher fills with water and then the heater is supposed to turn on to heat the water. If the water does not heat, then it will display 2H continuously. The heating element may be bad, but a more likely cause is with the control module. Bosch has a problem with the control module printed circuit (pc) board that powers the heater on many models. The solution requires some technical expertise and soldering skills. The details are explained in the document "Bosch dishwasher troubleshooting tips" on page 11. Download here
Bosch recommends re-soldering the connection, which is a temporary fix. The problem is that the copper conductor (called a trace) on the circuit board is not wide enough to handle the current required for the heating element, and as a result the copper trace overheats, causing the solder to melt on the relay connection. The best solution is to remove the control module PC board and solder a short length of copper wire between the pins to prevent the overheating problem, as shown in the attached photo (magnified portion of PC board). I did this on my dishwasher and it has been trouble-free for over 3 years.
What did h01error code mean ? Answer me plz
Is yours a Bosch machine? On Bosch the H01 usually means you have turned on the Delayed Start feature on the machine. H01 means the wash cycle won't start for one hour, H02 means it won't start for two hours.
Try this website to see how to turn it off.
Aug 11, 2021 • Dishwashers
2answers
EdgeStar DWP61ES turns itself on and off, display shows H:01 then counts up through H:24 then either turns off or starts the count again.
Many owners of the Bosch dishwashers perceive h01 (h: 01) or h02 (h: 02) and other signs as an error. But in fact, this is not an error, and you accidentally got into the start-up timer menu (delayed start of washing dishes). In this case, h01 means that washing dishes will start exactly in 1 hour; if the display shows h02, then washing process will begin exactly in 2 hours. As a rule, in most models of dishwashers from Bosch, a delayed start can be set in the range from 1 to 24 hours.
Timer programming You can delay the start of the program in 1-hour steps up to 24 hours.
  1. Close the door.
  2. Switch on ON/OFF switch [1].
  3. Press button [4] + until the digital display [9] jumps to h:01
  4. Press [4] + or - button until the displayed time corresponds with your requirements.
  5. Press START button [6], timer programming is activated.
  6. To delete timer programming, press the [4] + or - button until h:00 is indicated on the digital display [9].
You can change your program selection at any time until the program starts.
FOR LINK https://bosch-dishwasher-errors.com/bosch-dishwasher-error-code-h01-h02/
3answers
I have Bosch dishwasher model SHX68E05UC. Code says h:02 what does this mean?
Read more at https://bosch-dishwasher-errors.com/bosch-dishwasher-error-code-h01-h02/#uGUAe8vpcVfLM3YX.99
Bosch Silenceplus 44...just out of warranty... My dishwasher has an E 27 error code and will not start, anyone have any ideas?
In the instructions for different models of Bosch dishwashers, the e27 error is described as insufficient voltage in the electrical network. This means that if the mains voltage drops below 220V (or 110V in some countries), the dishwasher stops working, and the E27 error code appears.
What does Ho1 mean on the screen?
Some Bosch dishwashers have a time delay option. The H01 indicates a one hour delay has been selected. Press the Delay key several times until you see H00 in the display. Then try to start the dishwasher cycle you need. Bosch error codes tend to start with E.
Please add a comment with the model number of the dishwasher if you need additional help. (Without the model number, I can't be sure which key sets the time delay. On some models, the key is near the On/Off button. On others, it's closest to the Start button.) I hope this helps.
Bosch silence plus 50 dba is showing error code h01
I believe this is a filling or water flow error. Make sure all the plumbing stuff is OK look at the valve under the sink that feeds the dishwasher. make sure it has not gotten turned off. Sometimes with hot water and cold also a chunk of crud will break off somewhere and get lodged blocking or restricting the flow. You may also have a filter somewhere on the DW to prevent junk from getting in. If there is a piece of crud a likely spot for it to be is at the valve connection under the sink where the DW hose connects to the hot water line. You can try unhooking the DW supply hose from the shut off(turn the shut off OFF first) and seeing if there is any junk in it. Shake the hose about 8" back from the end to try and send any junk in it flying across the kitchen. Also open the valve a bit with a bowl under it to blast any junk out. also see if it seems like a decent amount of water comes out to rule out any upstream plumbing issues.
Bosch silence plus 50 dba has error code h01
The statement below can be found at: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html,
The SHU4326 and 4326 models use "Regular Wash" and "Rinse Hold" to begin the test while the other three series in this section use "Scrub Wash" and "Delicate/Econo," but all use the same set of fault codes, shown not as lights but as numbers on the Cycle Countdown display. Here, 1 is an aqua sensor fault, 2 is a heating fault, 4 is a filling fault, 8 is an NTC fault and 0 means that everything is working as it ought. During an actual wash, when you aren't testing, the Cycle Countdown display may show the letter "F," which also signifies a filling fault.
Read more: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html#ixzz33JutQVQR
79helpful
2answers
Display has error code h01 and dishwasher won't run model is SMS63M08AU
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
