Panasonic TC-P55S60 Logo
D
Don Wolk Posted on May 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does debug shown on my screen?
How do I remove debug from my screen
  • Official Brand Answer 350 Answers
  • Posted on Jun 06, 2014
Panasonic
Level 0:
Answers
350
Questions
0
Helped
84476
Points
487
The word "Debug" is not part of Panasonic TVs. We recommend you contact the source provider so they may properly assist you.
How to Enable USB Debugging on Android with Black Screen?
USB debugging must be enabled in order to perform actions on your phone from your computer. This guide takes a look at how to enable USB debugging on Android with broken black screen using a couple of different ways.
- Part 1. Enable USB Debugging on Android with Black Screen Using ADB Command
- Part 2. Enable USB Debugging on Android with Broken Screen Using OTG Cable and Mouse
- Part 3. How to Recover Lost Data from Android with Black Screen
**Part 1. Enable USB Debugging on Android with Black Screen Using ADB Command**
One of the ways to enable USB debugging on your Android phone with a black screen is to use an ADB command. There is a command that you can use with ADB toolkit and that should help turn on the USB debugging option on your phone.
The following describes how to enable USB debugging on Android with black screen through computer.
- Download theADB toolkitfor your computer and extract its contents to a folder.
- ADB requires you have USB debugging enabled on your phone. Since your phone has a black screen, reboot your phone into recovery mode to accomplish this. Press the Volume Down and Power buttons at the same time to enter recovery mode.
- Connect your phone to your computer, open a Command Prompt window in the ADB folder, and type the following command.
adb devices
- You should see your device listed there. Run the following commands one by one.
adb shell
mount data
mount system
- Use the following command to pull the persist.sys.usb.config file from your phone to the PC.
adb pull /data/property/persist.sys.usb.config C:\Users\\Desktop/build.prop" /system/
- Reboot your device using the following command.
adb reboot
You are all set. Your phone will boot up with USB debugging enabled.
**Part 2. Enable USB Debugging on Android with Broken Screen Using OTG Cable and Mouse**
If your phone has support for OTG, then you can actually plug a computer mouse into your phone and use it to navigate around on your device. This way, even if your phone has a dysfunctional black screen, you can still perform various actions on your phone. The following shows how to enable USB debugging on Android with a black screen using a mouse.
- Connect your mouse to your Android phone using the OTG. Make sure your phone supports the OTG feature.
- You will probably need to mirror your phone's screen to your computer, if you cannot see anything on your phone.
- Use the mouse to head into Settings > About phone > Developer options and tap on the Build number 7 times to enable the Developer Options.- Back to About phone section and you should find the USB debugging option. Click on the option to turn it on.
USB debugging is now enabled on your device.
tip
SAMSUNG T100 SECRET CODES
<span> *#06# -&gt; Show IMEI <br />*#9999# -&gt; Show Software Version<br />*#0001# -&gt; Show Serial Parameters <p>*2767*3855# -&gt; Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!!!! but also change IMEI to 447967-89-400044-0, you must use CHGIMEI to restore it)<br /> <p>*2767*2878# -&gt; Custom EEEPROM Reset<br />*#8999*228# -&gt; Battery status (capacity, voltage, temperature) <br />*#8999*246# -&gt; Program status <br />*#8999*289# -&gt; Change Alarm Buzzer Frequency <br />*#8999*324# -&gt; Debug screens <br />*#8999*364# -&gt; Watchdog <br />*#8999*377# -&gt; EEPROM Error Stack <br />*#8999*427# -&gt; Trace Watchdog <br />*#8999*523# -&gt; Change LCD contrast <br />*#8999*544# -&gt; Jig detect <br />*#8999*636# -&gt; Memory status <br />*#8999*746# -&gt; SIM File Size <br />*#8999*778# -&gt; SIM Service Table <br />*#8999*785# -&gt; RTK (Run Time Kernel) errors <br />*#8999*786# -&gt; Run, Last UP, Last DOWN <br />*#8999*837# -&gt; Software Version <br />*#8999*842# -&gt; Test ******** <br />*#8999*862# -&gt; Vocoder Reg <br />*#8999*872# -&gt; Diag <br />*#8999*947# -&gt; Reset On Fatal Error <br />*#8999*999# -&gt; Last/Chk<br />*#8999*9266# -&gt; Yann debug screen (=Debug Screens?) <br />*#8999*9999# -&gt; Software version<br /></span>
on Jan 11, 2011 • Cell Phones
tip
Solution for nikon "lens Cover Error"
Nikon Coolpix S5/S6 “LENS COVER ERROR”
In this document I have given a solution to fix the problem most of the Nikon coolpix S5/S6 cameras face. At power –on it give an error “Lens Cover Error”
Before opening the camera I would suggest you to take a snap of each and every step. Because it will helpful while you are fixing the screws back. There are many screws which has to be opened. So better take a photo of each and every step.
IMP NOTE: Remove the battery before opening the camera. Use some antistatic strip to prevent the components from getting damaged Or Keep your feet touched to the floor such that your body remains grounded.
Follow the below steps in the given order:
Step 1> Remove the screws at the bottom of camera
Step 2>Remove the side screws
Step 3> Remove the side screws as given below .
Step 4>Lift the cover and remove the cables which connects the switches to the camera. These cables are fitted in a small connector. There is a tiny lock (present for few connectors)  on the connector, which on pulling it across its hinges, will open and the cable comes out easily. You need not pull it forcefully.
Step 5> Remove the screw as shown below
Step 6> Lift the screen as shown below.
Step 7> Remove the cables and screws as shown below.
Step 8> Lift the screen panel as given below.
Step 9>
Remove cables as shown below.
Step 10>
Remove the cables as given below.
Step 11> Remove cables.
Step 12> Remove cables
Step 13> Remove the 4 wires using a soldering iron.
Step 14>
Step 15> Removing at this stage is a bit difficult. You will have to open it cleverly. Lift it from the side as shown below.
Step 16>
Step 17>Below figure shows the lens cover and the stepper motor which controls the lens civer.
Step 18> To remove the stepper motor remove the screws as given below.
Step 19> Below figure shows the stepper motor used for lens cover
Step 20> Below figure shows the stepper motor which is used to control the lens cover. There is a small white switch on this motor. This Switch is used by the camera to detect whether the camera lens cover has is open or closed. When we switch on the camera the lens cover (which is shown in step 17) opens and in turn it presses the white switch show below. If the lens cover is unable to press this switch, then the error “Lens cover Error” flashes on the camera.
I would suggest 3 different ways to solve this problem.
1>     Fix some glue on the white switch shown in the below figure, such that it remains pressed forever. Because of this, camera will never give the error message. Remove the lens cover (which is shown in step 17) forever. You don’t  need it anymore. Now fix the below stepper motor back in the camera and follow the steps in the reverse order to fix the camera components.
2>     Buy a new stepper motor from the market. Its quite cheap. Fix it back in the camera. Here you need not remove the lens cover. Follow the steps in the reverse order to fix the camera.
3>     In this method you can open the stepper motor to fix the problem. Now follow the steps given below.
Step 21>
Remove the screws as shown below.
Step 22> Remove the gears one-by-one. See the placements because you have place them again in the right order.
Step 23>
Step 24> The gear shown below is the culprit. Remove it. There is a tension spring present inside this gear. Do remember the position of this gear before removing this gear. Its placement is very important.
Step 25> The spring is shown below.
Step 26> Now the switch shown in step 20 does not get pressed because of reduced tension of the spring. Increase the tension of this spring by pulling it in opposite direction. Place the spring back in the gear and follow the steps in the reverse order to solve the problem. Now because of increased tension of the spring, the lens cover will be able to Press the switch shown in fig 20.
Happy debugging
Mukesh
1helpful
The word "Debug is on my tv screen. How do I remove it?
Unplug the power cord of the receiver box for 10 seconds and then plug it back.in job done..
1helpful
Word "debug" on my vizio tv screen
Sounds like firmware corrupted. A firmware update might be necessary. Contract the authorized service center for Vizio.
Gopakumar Gopalan Google
Debug message on far side of Screen
Firmware corrupted. Contact the authorized service center.
6helpful
The word debug is on the screen. how do i take it off?
Default password of Samsung S3850
*#9998*289# : Change Alarm Buzzer Frequency *#9998*364# : Watchdog *#9998*523# : Change LCD contrast - Only with version G60RL01W *#9998*746# : SIM File Size *#9998*862# : Vocoder Reg - Normal, Earphone or carkit can be selected *#9998*786# : Run, Last UP, Last DOWN If the up Codes doesn't work, you should change *#9998* to *#0. i.e. *#9998*523# change to *#0523#. An other thing that will help is to remove your SIM card. *0001*s*f*t# : Changes serial parameters (s=?, f=0,1, t=0,1) (incomplete) *0003*?# : unknown *0003*?# : unknown
*#9998*377# : EEPROM Error Stack - Use side keys to select values. Cancel and ok *#9998*427# : Trace Watchdog *#9998*785# : RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error. *#9998*778# : SIM Service Table *#9998*947# : Reset On Fatal Error *#9998*872# : Diag *#9998*999# : Last/Chk *#9998*324# : Debug screens *#9998*636# : Memory status *#9998*544# : Jig detect *#9998*842# : Test ******** - Flash the screenligth during 10 seconds and vibration activated *#9998*837# : Software Version *#9998*228# : Battery status (capacity, voltage, temperature) *#9998*246# : Program status *#9998*9266# : Yann debug screen (=Debug Screens?)
*#9998*9999# : Software version
SP-unlock SGH-600 (and also SGH-Sgh-600 *2767*3855# : Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!! ) But also changes IMEI to 447967-89-400044-0. (Doing this is illegal) *2767*2878# : Custom EEEPROM Reset *These codes have been tested with version FLD_2C6 G60SB03X of Samsung SGH-600 Samsung SGH-600 Unlock Codes *#9999# : Show Software Version *#9125# : Activates the smiley when charging. *#0001# : Show Serial Parameters *#0837# : Show Software Version (instructions) *#06# : Show IMEI
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
