Razor USA Razor Dune Buggy Logo
A
Anonymous Posted on May 18, 2014
I have a razor dune buggy but cant get it to work? how does the throttle work?
1 Related Answer
Anonymous
  • Posted on Aug 18, 2012
SOURCE: Razor Dune Buggy Problem
I have the same issue with mine. Batterys check out fine.. i'm starting to suspect the motor??
1helpful
1969 VW-Engined Dune Buggy Cranks but Won't Start
You need a wire that receives 12v+ when the key is turned on to the coil+. Apparently the wire that you have hooked to the coil is bad or not the same one that runs to the ignition switch.
My Razor Dune Buggy Don't Show signs of life after installing battery
Fuse blown I wonder .....
If it had, look for the issue.
How to find replacement clutch cable M T D rear tine tiller with no sereal number
you can do what i did and resoider or re crimp the cable go to the hardware store and buy a generic cable and fabricate your own.i did this for my 2 year old mtb lawn tractor as i was too cheap to spend the 50 buck for a crappy 1/8 thick cable that the manufacter knew was going to fail.I used a spare throttle cable from my vw dune buggy and cut it to fit.
2answers
My razor dune buggy won't drive
are you sure that the charger is putting out enough volts to charge the batteries? check the charger with a multimeter, then check the batteries with a multimeter, and viually inspect the batteries for bulging
How can i get the instructions for the mega Mega Bloks Pro Builder Dune Racer Buggy 9763 i dont have the instructions
You can find the instructions for this Mega Bloks set and loads of others at the Mega Bloks wiki - Blok City
If you follow the link below and then go to the bottom of the page you'll find the instructions for the Probuilder Dune Buggy
http://www.blokcity.com/wiki/index.php?title=9763_Dune_Racer
Buggy is removing charge from battery
try investing in a battery charger instead of replacing the battery the dune buggy probably doesn't have an altinater to recharge the battery
Unknown make of engine
generally the dune buggy was made by a volkswagen chassis and engines
Can not get power to my pyle amplifier
Usually On Car Amplifiers, there is a Connector/Wire called "Remote On".
This is where Headunit supplies 12V to trigger the Power on the Amplifier.
(Of course, head unit usually has Remote Wire also in order to turn the Amplifier on).
If this wire is properly connected and still does not turn on, then try to supply 12V directly from the battery. If it turns on then your head unit has problem, If it does not turn on then your Amplifier has problem.
Top Razor USA Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Razor USA Toy Expert? Answer questions, earn points and help others
