Dell 1815dn All-In-One Laser Printer Logo
L
Linda Spring Posted on May 19, 2014
Why do I have lots of vertical lines on my copies? Put in a new toner cartridge but that didn't fix the problem. Anyone have an idea what could be wrong?
aic7
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on May 19, 2014
aic7
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
Helped
6952
Points
31
Drum unit is damaged or scratched. Replace drum. Certainly sounds like a mechanical issue rather than a software issue. I had a similar issue on my laser printer, and replacing the drum solved it.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Nov 29, 2007
SOURCE: Dell 1600n and vertucal line while scanning
Any difference between using the document feeder and just the flat bed?
Anonymous
  • 3587 Answers
  • Posted on Feb 25, 2008
SOURCE: 5100 cn will not print black
hmmm...with that, it's more a power supply issue, since that's what's needed for that..
I have a copy of the service manual, if you want. Send me a note through my profile's email addy, and I'll see if you can get that one(It's an adobe pdf document)
check your computer's warranty here FREE
Anonymous
  • 448 Answers
  • Posted on Jan 01, 2009
SOURCE: excess toner after ?overfilling cartridge w/ bulk toner
Did you refill the toner yourself or put a new one in or.......
Anonymous
  • 3 Answers
  • Posted on Jan 14, 2009
SOURCE: Black lines on the right side of every copy
depending on what the lines look like it could be the charge roller or transfer roller.
A defect on the charge roll appears as black areas on the front of the test page, and as light gray areas on the test page.
A defect on the PC drum of the toner cartridge appears as white areas on a dark, full–coverage test print and as black areas on the "text only" test page.
I have also seen a line with a 'ridge' on the paper. This will appear almost like an embossed line. This was caused by the fuser roller being scored by debris.
Anonymous
  • 741 Answers
  • Posted on Mar 29, 2009
SOURCE: vertical line on copies
A vertical line on laser copiers which are the same lenght apart on each indicates a dirty or defective toner cartridge or dirty or defective rollers. Take the cartridge out and wipe the rollers with a soft cloth. If the streaks continue then the rollers inside the cartridge or damaged. You will need to replace the toner cartridge. Let me know if you have any questions. Please rate this solution with 4 diamonds.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
1helpful
2helpful
2answers
Vertical line on paper from top to bottom
In my experience if you refill the toner cartridge with the toners available in the market,though they are labelled"for Brother 2140" you get vertical dark patches on the paper. Once in a while you get good quality print too. Replacement with correct toner cartridge seems to the solution.
2helpful
Vertical blank "line" on printed material.
try the toner cartridge. You can see where its coming from by printing 1 page. When the page starts coming out of the machine open the cover. Take out the toner cartridge and look at the page. The line should be there and you should be able to figure whats causing it. It's almost always the toner cartridge. If you have an old cartridge put it in and run a test with it. If the line is gone its the cartridge. Steven 818-888-0006
Black Vertical line on copies using MFC-8660DN
Vertical lines mean it is being caused by one of the rollers within the printer. This is usually either the toner cartridge or the fuser assembly. I would try changing out the toner cartridge first even if it is new as sometimes they are DOA and they are much cheaper than the fuser assemblies. If that doesn't work, probably the fuser assembly.
Black Vertical Lines
This can be caused by a damaged fuser or drum try to change the cartridge and if that does not resolved the issue then its the fuser
Vertical White Line printing down the page
Hello sir; I believe you have running out toner , try put a new one see what's happen.
Black vertical streaks on faxes & copies
On top of the toner/drum cartridge there should be a blue slider, move back and forth 10 times.
If no fix, you need a new toner cartridge.
7helpful
3answers
Printer putting line down the page
I had a hp 3050 yesterday with two vertical lines running down the page when making a copy. All I had to do was to pull open the top cover where you put the paper you want copied and cleaned the glass strip with a rag and alcohol and the lines were gone.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
