This is caused by a blocked defrost drain. The cold air for the fridge is vented from the evaporator behind the freezer. Once every 24 hours the defrost timer, stops the compressor and applies power to a heater at the freezer evaporator coils. The defrosted water drips and runs to a drain normally into a metal tray on the compressor where it evaporates. On my GE fridge freezer there is a hose and a small p-trap at the rear. Easy to remove, soak in bleach and hot water and then flush through. Help for Samsung drains in the link.
*** The following is for information only.***
* The symptom of melted ice and water dripping from tray is usually caused by several things;
* Most common is ice build up in freezer coils. This happens every time the door is opened. Ice builds up on coils but is normally removed during a daily defrost cycle.
* The cycle may be unable to defrost all ice due to bad air circulation. Usually caused by rubbish blocking fan intake (bottom of freezer tray or wall.) Overloading food may cover the intake.
* Remove all food from freezer. Check for fan blockage. There should be a steady flow of cold air. If not then your freezer needs to be defrosted.
* Defrost by moving all frozen food to fridge side or cooler. Unplug fridge and open freezer door (drawer). Allow room air to circulate into the freezer. Use a house fan to blow air into freezer. (DO NOT use Hair dryer! It will damage panels.)
* Check and remove melted ice water. Check inner panels of freezer. Once defrosted the panels will be room temperature to the touch. There should not be any condensation or coldness to the panel. If it's still cold then keep defrosting.
* Once the water stops dripping. then close freezer doors.
* plug in freezer and wait 5 mins. Check freezer if inside is cold and the air is blowing cold. Reload freezer with food, take care not to overload or cover fan intake. Monitor for 2 days.
Believe it or not your freezer has a heater that defrost your freezer. It runs on a cycle to keep the ice from building up. Your freezer may be set to cold or the heater isn't working properly.
would check ur defrost terminator and defrost timer. should not have replaced control board so quickly. may even just have abad thermistor/ but I suspect ur defrost terminator is the problem and its rather inexpensive and easy to replace
There is a drain tube located under the panel of most freezers. If that clogs up, the auto defrost can't work. The freezer defrosts by evaporating all the moisture out of the compartment. So, check that first. Secondly, a leaky door seal can also cause that problem. You can order door seals online or on Amazon.
defrost issue , not sure on how to jump the board to force defrost but more than likely the defrost thermostat is bad . this is on the evap in freezer . the noise come from frost building up around the evap fan
Hi, if freezer is icing up, you might have a defrost problem. Frost free
models have a heating element that is controlled by a timer to
automatically defrost ice, defrost timer turns on defrost heating
element every 12 hours to melt ice in freezer and allow good air flow. You
can test defrost element with an ohm meter(located inside freezer
coils-will have two wires going to a plug connection), if OK replace
defrost timer (located in various places depending on make and model)
