Question about LeapFrog Clickstart My First Computer
Leapfrog my first computer will not recoingise mouse movement
I have a leapfrog my first computer I have change batteries in both the console and the keyboard the mouse will light up but the mouse will not move on the screen. I have ensured that the sensor to each other are in line with each other but still will not work, I have also press the reset button on both. Can anyone give me any other suggestions on what to do.
  • Mutta May 19, 2014
    Promblem Solved! Apparently i had one old battery mixed up with my new ones, fixed the issue straight away
SOURCE:
SOURCE: Keyboard doesn't work
are you sure you have the keyboard near enough and pointing towards the computer unit. As it is said that it works wirelessly (which obviously is correct as there are no wires) but this normally means wi-fi which can be moved anywhere however the clickstart works with the very unreliable infa red so the unit needs to be close and pointing towards the keyboard. hope this helps
Posted on Jan 06, 2009
SOURCE: Using the Leapfrog click start TV computer game, the TV scrolls.
In the battery compartment to the cosole there is a switch, one is for the US. switch the lever to this side and it should work fine
Posted on Jan 16, 2009
SOURCE: LeapFrog Click Start mouse problem
I bought my son a click start for Christmas and after about 10 days we had this problem as well. If you remove the back plate where the mouse plugs into the keyboard and sort of wiggle and push the cord inward and then replace the plate cover the mouse should work again. I have had to do this several times, which is kind of annoying, but I suppose it's worth it since my son really loves the toy.
Posted on Jan 22, 2009
  • 16 Answers
SOURCE: Leapfrog Clickstart doesn't switch off and doesn't work
You blew the circuit board by putting to much power into it. Never use more power then suggested for this reason. All adaptors have a volt and an amp rating. Sorry it happend best wishes!
Posted on Feb 01, 2009
  • 6 Answers
SOURCE: mouse not responding
Not a real suggestion for solving your mouse problem but you can
use Mousk until your mouse problem is fixed. www.channels.nl/mousk
Posted on May 02, 2010
Involuntary mouse movement
Are you using wireless mouse? if so, try replacing battery. Still not working? replace mouse. If USB mouse, try changing the mouse pad. Still trouble? try different USB port and update BIOS.
Jan 23, 2012 | Computers & Internet
Our leapfrog 2 console got water in behind the screen and now won't turn on..............can it be fixed?
Yes all you have to do is (first of all check the batteries) find out whitch parts of the console is not working (I don't know how sorry about that) and replace it. Wish i could be of more help. maybe try going to the
LeapFrog LeapSter L-Max Console website
Sep 30, 2010 | LeapFrog LeapSter L-Max Console
Click start game for leapster. Mouse does not work. Keypad lights up but mouse does not. I have reset the keyboard and still nothing. Any ideas?
mcdevito75 here, Do you also have to re-set the mouse?? Refer to the instruction manual for info. Also does the mouse take a battery?? Call or visit Leap Frog online for more info.
Jun 26, 2010 | LeapFrog ClickStart My First Computer
Mouse not responding
Apr 24, 2010 | LeapFrog Clickstart My First Computer
The mouse on my daughter's learfrog clickstart barely moves the cursor on the screen. How can I fix this? I've already replaced the batteries
Make sure there is nothing blocking the path between the keyboard and the console. It needs line of sight to work properly. If this doesn't help; I'm sorry. This fixed my problem with the same issue.
Feb 12, 2010 | LeapFrog Clickstart My First Computer
Mouse not working on Click Start - Leap Frog
I am still waiting to know what to do.Is there a substitute for this mouse?
Jun 11, 2009 | LeapFrog ClickStart My First Computer
Leapfrog mouse doesn't respond on screen
We had this happen within the first 30 minutes that we owned the Click Start! It still happens periodically when the kids are using it. For us the LED lights are flashing non-stop on the keyboard, and the mouse does not move the cursor on the screen and you cannot "click" on anything either.
Solution: On the underside of the keyboard is a very tiny hole. Push a pin or a paper clip into it, you'll feel some give in there like you are pushing a button. I push it until the lights stop flashing on the keyboard. It's the reset button. So far this has worked for us everytime.
Good luck.
Jan 18, 2009 | LeapFrog Clickstart My First Computer Pink...
Jan 10, 2009 | LeapFrog ClickStart My First Computer
Mouse not responding.
I take it that you have a wireless mouse.
Myself I prefer the ones that plug into the console.
Jun 18, 2017 | Micro Innovations KB1045LSR Keyboard
LeapFrog Clickstart My First Computer Logo
197 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
pramey3
Level 1 Expert
Keith Koene
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
