One o the rings on my Neff t1252noeu has just stopped working, and I need it repaire quickly - can this be repaired?One o the rings on my Neff t1252noeu has just stopped working, and I need it repaire quickly - can this be repaired?
You can't post conmments that contain an email address.
Take a closer look at the wiring diagram on the base or in the book.Check you have put in the relevant links.If not wired properly you may only get half the hob working.
i have an electrolux model ekt 6045 it does not stay on it comes on for 1sec then goes off wot would be the cours of this please the oven stays on but the hob doesent thank you.
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
check that the hob is wired correctly underneath 1,2,3 should be linked together as live 4,5 as neutral and earth takes its place as earth,
if it is wired correctly then i m afraid the hob needs a new induction element it is all one complete unit on these hobs not seperate so your looking at £1000 + to fix it plus engineer call out charges
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
You press the "on" which is on the left. Press the picture of hob you require and press the up and down for temperature. Then put your pan on the hob and it will work. If you need to adjust the temp you need to remove the pan.
