Error Code 15: OC Driver Error
This error occurs when the Mechanism Control ASIC detects that a
single phase of the OC Motor was energized for longer than the allowed period of time. This indicates a malfunction of either the HCPP motor, or ROM Board driver circuitry (TA10: STA485A), or both.
1. Check OC motor connector CNO/C on the Sensor Board.
2. Check both the OC motor and the OC motor driver circuitry on the
ROM Board. To replace the ROM BOARD If necessary, replace the OC MOTOR
oc failure computer. oc failure boot. oc failure error. oc failure bios. oc pc failure. oc power failure. your description don't have so many details. GOOGLE IT.
You neglected to specify the make and model of your camera so I'm assuming it uses a memory card of some type.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
