Based on what you've told me, it sounds like you're experiencing an issue with your Cuisinart TOA-65 appliance. You mentioned that you removed the cover to clean it, and now you're getting an error code E01 on the display when you plug it in.
This error code could indicate a problem with the appliance's safety interlock switch. The safety interlock switch is a safety feature that prevents the appliance from operating unless all of the components are properly assembled and in the correct position. It's possible that the safety interlock switch was damaged or dislodged when you removed the cover to clean it.
To fix this issue, you'll need to locate and re-engage the safety interlock switch. This may require disassembling the appliance and reattaching the switch. I would recommend consulting the appliance's instruction manual or contacting Cuisinart for assistance. A qualified appliance repair technician may also be able to help you diagnose and repair the problem.
usually a key symbol means that the appliance is safety locked. usually by holding down a button for 3-5 seconds to lock and holding down the same button to unlock. a child lock safety feature.
Code 5 is a error on the safety valve. This could from a bad electric ignightor. I am not familiar with the grill so I am not sire if it has an electronic coil that heats up or just a popper to ignight. There could also be a obstruction in the gas line. Feel free to provide more information for me.to help you with
Dissconnected socket some were. One of the safety features of the system is or was disconeccted may have to dissconect memory battery to reset error message with out a user manual available
you can google the error message an find a solution there
The SI 1 error code means there is no safety key in place. Unplug your treadmill, wait a few minutes, then plug it back in.
When you try to use it again, make sure the safety key is firmly in place, and make sure the metal piece below the Emergency Stop sticker is still in place.
If neither of these work, it may be appropriate to take your treadmill to a servicer.
Your error code is for the fixing unit solve by checking the follwoing:-
1. Fixing lamp.
2. thermistor
3. Fixing assembly if receiving PD
5. if no Potential difference received they the power supply is not okey.
E4 error is in the fixing assembly. Check the following:-
1. Fixing lamp.(change if broken)
2. THermistor. (change it if not working propperly)
3. Fuser roller if in good condition.
4. If the fixing assembly is receiving the PD.
5. If the fixing assembly is not receiving the potential differrence then the Power supply is foult change it.
Make sure the magnetic safety key ('safety pull' or 'emergency stop magnet') is in place. SAFE OUT indicates that the safety key is not in position or is otherwise not working properly.
For more information consult the following manuals:
F then 2 flashes when in: Diagnostics Test mode if a stuck key is detected. Standby mode if there is a user interface mismatch. DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up: 1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control. 2. Visually check that the user interface assembly is properly inserted in the console assembly 3. If both visual checks pass, replace the user interface assembly. 4. Plug in washer or reconnect power. 5. Activate the Console and Indicators Diagnostic Test mode to verify repair. 6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard: 1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly. 2. Plug in washer or reconnect power. 3. Activate the Console and Indicators Diagnostic Test mode to verify repair. 4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators: 1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted into the front console. If visual check passes, replace the user interface assembly. 2. Plug in washer or reconnect power. 3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
what is the model number?
