SOURCE: Trying to Print USPS Labels from PayPal on TLP 2844
see if you can set the printer preferences to borderless printing.
SOURCE: which driver to use with lp 2844-Z under windows
Go to website below, and download the driver from there unplug device, install software and reboot, at next desktop, NOW plug in the unit and use.
SOURCE: Zebra LP 2844 doesn't feed label all the way out
Hi Brian,
When the last label printed is still under the printhead, that means the printer is in "rewind mode". There should be an option for "tear off" mode in the printer driver. This is the mode that pushes the last label printed out to the tear bar. The printer will then "backfeed" when printing the next label. Peel off mode is used if you want to print a label and have it "peeled" off the liner so that you can just pick up the label off the liner and apply it. That takes the rewind option to be installed.
Watch out though, if you are using a label software package, there might be a setting in the label format setup for "tear off" which usually overrides the settings in the printer.
Hope that helps !
SOURCE: Won't print last inch on label
http://www.zebra.com/id/zebra/na/en/index/service_support/options/technical_support.html?country=US&product=58
contact tech support for Zebra LP 2844 Thermal Printer.
