Hi i have a precor elliptical that was recently moved. not sure if the problem was there before but on the right foot stroke the crankarm is rubbing at the lower back rotation. i took the cover off, the bolt that holds the crank to machine was a bit loose. that helped reduce the rubbing at the bottom rotation but its still a bit there. ? anything else i should check ? Ingrid
SOURCE: Precor M9.21 Treadmill - Stops under load
This probably did not happened suddenly right? the problem is not the motor however you can easily check the blue capacitor for peace of mind. with the power disconnected, disconnect one side off the capacitor from the top. with a ohm meter put the 2 probes on the cap,you will ear a temporary beep sound from your meter, then reverse your probes on the capacitor and again a temporary sound that mean your capacitor is good and your motor will run OK.
Your problem is more then likely your run belt and bed assembly. When new, these are coated with a wax of some kind for slipping, has you use the machine wax wears off, and so is the belt. You can see a black rubber dust at the rear of the machine. And so resistance increase when pressure is applied on the running belt.
Just behind the on/off switch where the power cord goes in, there is a auto reset 15 amp breaker that trips when too must resistance against the motor increase the amperage over 15amps. At 7 min/m on your speed setting and if the belt is adjusted correctly with nobody on, the motor pull about 6amps, with someone like me 180lbs, the motor pulls an avg of 10amps with a new belt.
If you have a clamp amp meter you can test it yourself.
2 parts you will need to fix this; 50985-101 (bed assembly) and 36355-101 (run belt 17 X 110) This is real easy to install.
make sure these parts are for your machine model # as they did increased the width of their belt over the years
Since 1998 I had to replace these parts 2 times with an average of 3 people using the treadmill every day. This is a good machine and if everything else is good it's worth it. I paid $300 for these parts, i'm sure if you shoppe a little you can do better.
Have a good one
Ben
SOURCE: my proform 2605 elliptical the right foot pedal is
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
