How to install the front panel wireing like the power sw or pw led or the reset
SOURCE: reset/power/led etc..lead connections
hi bob i need to know the motherboard's serial number then shouldn't be a problem finding the service manual for it with all the information you require some motherboards got that information imprinted near the pins if you look close enough
SOURCE: foxconn motherboard pinout
Please follow this link and download the manual.
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0002117
Don't be surprise that the manual name is 662M03, it is still the right manual becuase is made for both type of motherboards.
SOURCE: Front panel connections
You can download the complete user manual in English from the manufacturer's website at this link:)
http://support.asus.com/download/download_item_4.aspx?product=1&model=P4B533&SLanguage=en-us&os=17
The front panel connector pinout is on page 2-33, or page 59 in the PDF file. You should have mor ethan enough information to make all the connections you need.
SOURCE: wires connection
If you know where the board came from i.e. a dell laptop model number or dell desktop model number this would help.
The issue is this is a
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
propretary version of the motherboard and can have different configurations based on what machine you got it from.
This is a link to the Dell Dimesion 8400 spec for that board.
The E210882 is commonly the D865GLC motherboard from intel spec is here.
SOURCE: Wiring front panel
if you go to this website
http://www.foxconnchannel.com/support/downloads.aspx
You can select motherboards --> socket 754 --> your make of motherboard and then download the manual which will tell you what the pins are for and where abouts they are on the motherboard.
